Tue, Jan 28, 12:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: Poser 4 crash's when i render to a new window
zxcvb ( ) posted Sat, 09 November 2002 at 2:23 PM ยท edited Thu, 23 January 2025 at 6:57 AM
hi can anyone help i have a P2 350 mhz computer with 384 mb ram with a voodoo 4 grapic's card and windows ME ,poser 4 i have brought a few thing from the market place and from daz and i have downloaded lots from freestuff the problem is when i render to main view alls well until i reander to a new window when i do this half of the things i have downloaded and brought make poser freeze half way though, then poser stop responding, things like daz dragon do this but nefris hair works ok i want to buy some new characters for poser but i have no way of noing if they . i have attached a pic of what happeds
Thanks
SamTherapy ( ) posted Sat, 09 November 2002 at 2:34 PM
More RAM would help, especially with models like the dragon. It's a hefty model and DAZ recommend lots of RAM. Also, a P2 at 350 MHz ain't exactly rapid, I'd seriously consider upgrading if you're going to be working on 3D stuff. A bigger HD helps a treat, too. By the way - 3D graphics creation will burn a hole in your pocket one way or another.
glennjan ( ) posted Sat, 09 November 2002 at 5:13 PM
I had the same problem with the 57 chevy except it would make a blue screen error when rendering in a new window......win98se....went to xp and that corrected everything I think it has something to do with 98 and ME because I Have a 1.3 Athlon with 512 megs ddr and a gforce card which are all newer components xp is the only thing I changed on my system to overcome this problem. Good luck
GizmoMkI ( ) posted Sat, 09 November 2002 at 5:31 PM
I was having similar problems until deciding that opening the separate window was dragging my memory down. I'm running an AMD 1.1 gig with 256meg ram under Windows ME. I changed my document window to 800x600, render everything to that, then export the image as a save file. No render crashes since (knock on wood).
rockets ( ) posted Sat, 09 November 2002 at 7:59 PM
Here's what I did to correct that same problem. Under render, render options...change resolution to 300. I don't know why this works, but since doing this have never had another crash while rendering.
My idea of rebooting is kicking somebody in the butt twice!
Norbert ( ) posted Sat, 09 November 2002 at 10:27 PM
Look at all the programs you have in the taskbar!!! Is that bar across the top, another 'permanent' taskbar for Lotus, that loads at startup, too?? With all that stuff running in the background all the time, I wouldn't be surprised if you only had 2 Megs of free memory BEFORE you launched Poser. There's 2 free programs you can download, that might help. "EndItAll" and "Rambooster". Run the 1st one, then the 2nd one, to free up as much memory as possible. I remember Poser doing that to me a while back. I might have had to reinstall. Can't remember for sure.
Spit ( ) posted Sun, 10 November 2002 at 2:39 AM
Wow, I think it's really nifty that a PII 350 can run Poser with all that background stuff going on. Actually I ran Poser 5 on a PII 450 with only 256 megs of ram until just a few months ago. But I didn't run as much in the background...no problems, except it was a bit slow (video was good though and I could use full texture display and full tracking...amazing). But the suggestion about those utilities is a good one.
zxcvb ( ) posted Sun, 10 November 2002 at 6:50 AM
will give them programs a try, think i might have to get a new computer Thanks for your help
Darkginger ( ) posted Sun, 10 November 2002 at 12:13 PM
Norbert - I can't thank you enough. I followed the advice you gave above, and for the first time in a year, can render away happily without crashing! Yippee doesn't come close to expressing it!
