Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Try this..
Go into the material room and select a material on the figure and save it to the library.
Try it with the bump node connected and disconnected.
Then open that in a text editor and see what might be different.
I would do this myself, but I don't have the files to play with right now.
-Jeff
Hi guys, May be someone can help me... I'm trying to make a MAT files applying/removing bumps from my character and here's the problem: Poser5 applies the bumps, but doesn't remove them: it doesn't disconnect the bump node. I've tested both MAT's in P4 and everything works just fine... Here's a sample of MAT applying the bumps: { figure { material SkinHead { bumpStrength 1 bumpMap ":HeadBump.jpg" 0 0 } (...) } } Here's the file which is supposed to remove them: { figure { material SkinHead { bumpStrength 0 bumpMap NO_MAP } (...) } } Any suggestions on what I'm missing? Larissa
