Thu, Nov 14, 1:26 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Suggestion needed: P5 MAT files applying/removing bumps
larissad ( ) posted Wed, 13 November 2002 at 1:33 PM ยท edited Wed, 13 November 2024 at 2:35 AM
Hi guys, May be someone can help me... I'm trying to make a MAT files applying/removing bumps from my character and here's the problem: Poser5 applies the bumps, but doesn't remove them: it doesn't disconnect the bump node. I've tested both MAT's in P4 and everything works just fine... Here's a sample of MAT applying the bumps: { figure { material SkinHead { bumpStrength 1 bumpMap ":HeadBump.jpg" 0 0 } (...) } } Here's the file which is supposed to remove them: { figure { material SkinHead { bumpStrength 0 bumpMap NO_MAP } (...) } } Any suggestions on what I'm missing? Larissa
JeffH ( ) posted Wed, 13 November 2002 at 2:44 PM
Have you tried this just to see what would happen?
figure
material SkinHead
bumpStrength 0
bumpMap NO_MAP
0 0
larissad ( ) posted Wed, 13 November 2002 at 2:53 PM
Yes I tried that one too. P5 applies the first Mat no problem. The problem is that it doesn't want to remove the bumps after I apply the second MAT (with or whithout two zeros). The bump node is still connected...
JeffH ( ) posted Wed, 13 November 2002 at 3:12 PM
Okay, but does it change the bumpstrength to zero? This may have something to do with the material nodes.
larissad ( ) posted Wed, 13 November 2002 at 3:17 PM
No it's still shows 1 or whatever bumpstrengh I apply in the first MAT
JeffH ( ) posted Wed, 13 November 2002 at 3:28 PM
Try this..
Go into the material room and select a material on the figure and save it to the library.
Try it with the bump node connected and disconnected.
Then open that in a text editor and see what might be different.
I would do this myself, but I don't have the files to play with right now.
-Jeff
larissad ( ) posted Wed, 13 November 2002 at 3:31 PM
Thanks Jeff, I'm going to try it. Larissa
