Tue, Dec 24, 7:12 AM CST
Subject: important life changing poser question to ponder (probably not a trick!)
IReilly277 ( ) posted Thu, 14 November 2002 at 11:01 PM ยท edited Tue, 24 December 2024 at 7:12 AM
Ok little bit of a trick to get people to read this. I have P5. How do I get jpg images on squares, to be as bright and sharp as if I used them as background. I dont want a brick wall or shiny marble on my square i want my own jpg damn it! Thank you very much.
Little_Dragon ( ) posted Fri, 15 November 2002 at 12:33 AM
1) Load a square prop from the Library
  1. Select the square, then go to the Material Room (CTRL-U).
  2. Set Diffuse_Value and Specular_Value to 0. This turns them off.
  3. Attach a 2D image map node to the Ambient_Color channel, as follows:
Left-click on the little plug icon next to Ambient_Color to get the popup menu.
New Node --> 2D Textures --> image_map
  1. Load your jpg into the Image_Map node.
  2. Set Ambient_Value to 1 for maximum brightness.
Now try rendering it and see how it looks.
IReilly277 ( ) posted Fri, 15 November 2002 at 12:43 AM
Thank you little dragon!!! It works swell!!! Yay!!!
Lapis ( ) posted Fri, 15 November 2002 at 12:55 AM
That little dragon's pretty smart.
doldridg ( ) posted Fri, 15 November 2002 at 2:00 AM
Note when you do this, though, that it is like using a process screen in cinema. The square is actually "lit up" with the image and will not take shadows. If you want them you have to add them.
