Sun, Feb 16, 5:32 PM CST
Subject: *** Posette's Measurements - P4 *** ........... taken
geep ( ) posted Fri, 29 November 2002 at 5:21 PM · edited Fri, 14 February 2025 at 10:31 AM
cheers,
dr geep ... :o]
edited 10/5/2019
atthisstage ( ) posted Fri, 29 November 2002 at 5:34 PM
Uhm, Geep? Got too much time on yer hands, bud.... :)
geep ( ) posted Fri, 29 November 2002 at 5:49 PM
... WAY too much. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Lapis ( ) posted Fri, 29 November 2002 at 6:34 PM
How much does she weigh?
geep ( ) posted Fri, 29 November 2002 at 6:41 PM
... zero. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
tasquah ( ) posted Fri, 29 November 2002 at 7:18 PM
hmm sorry but i have to disagree about the breast size . I will give you the waist and hips but not the breasts . They are closer 34's .If you follow the line up the back in your render you will notice were the angel turns sharply then smouths back out right were you get your mesurment from . I checked my possete and it was from the shoulderbones and the pose. So discounting them and following the natural curve more you will see a different size.
geep ( ) posted Fri, 29 November 2002 at 8:08 PM
You are more than welcome to disagree, but ..... ... these measurements were derived by taking the P4 nude woman mesh and importing to RDS 5.5 using a scale of 1:100. An artificial "tape" was then used in the position shown and then the length of the "tape" was found by obtaining the length of each segment of the "tape" and adding all the segments together. The same method was used for all 3 measurements, so if you buy 2 of them ..... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 29 November 2002 at 8:11 PM
I had fun taking these measurements. You can take it for what this information cost you ...... ... nothing. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Fri, 29 November 2002 at 8:12 PM
... all I have to do is adjust the yRotate parameter dial. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
tasquah ( ) posted Fri, 29 November 2002 at 8:29 PM
hehe Well that not what i ment only that a slight adjustment should be made for the shoulder bones that in a real gal wouldnt have been poking out like they do in possette. With her arms up it changes the dimmensions some . You did a wonderfull job mind you . I was kind of wondering my self what the default mesurements were for possette , vicky and steph.
Jaqui ( ) posted Fri, 29 November 2002 at 8:46 PM
hmm, she looks like she has more hips than 32", I would have figured her hips for 36 as well. ahh now I see where the difference is, you measured her hips above the widest point.
geep ( ) posted Fri, 29 November 2002 at 10:58 PM
I'm not an expert mindst you, but ... ... I believe that the hips are always measured at the hip-bone, are they not? Can any of you ladies jump in here and help the ol' geepster out with this one? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
tasquah ( ) posted Sat, 30 November 2002 at 12:13 AM
Attached Link: http://www.diceyhome.free-online.co.uk/Sewing_Room/Measuring/Taking-measurements.htm
Thats called High hip its lower .
Bust - Run the tape along the fullest part of your breast and around your back going under your arms. (Not your bra size)
Waist - Find the smallest part of your waist, it is usually just above your belly button
Hips - Find the widest part of your hips on the hip bone.
hauksdottir ( ) posted Sat, 30 November 2002 at 1:09 AM
Dr. Geep, The fullest part of a woman's hips is often about 7" down, but sometimes lower. Most women have high rounded behinds as well as a bit of tummy fat... to fit into jeans or tight skirts the "hip size" has to accomodate padding on rear and front, so the >>>widest<<< part is needed. On the side you can usually feel an upper and lower bone, go for the lower one and adjust until you hit the widest spot. Posette is swaybacked in your side view, so you might want to square up her abdomen and hip anyway before measuring. Carolly
geep ( ) posted Sat, 30 November 2002 at 1:32 AM
... strange (and absolutely WONDERFUL !!!) but complicated figures ...
... this wouldn't be so difficult to determine.
Why am I doing this you ask?
Well, I guess I just have way too much time on my hands.
If you don't believe me, just ask atthisstage, they'll tell you. ;=]
Carolly,
Thanks for the feedback, but ...
7" down from what? ..... the "hip" line that is shown in the above pic?
"On the side you can usually feel an upper and lower bone, go for the lower one ..."
I'm not gonna touch THAT one with a ten foot ... (you know what) - even though the thought is very provacative !
"Posette is swaybacked in your side view, ..."
Posettes pose is with all parameters "zeroed."
And, I agree, she does have a bit of a swayback.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Bobasaur ( ) posted Sat, 30 November 2002 at 11:57 AM
geep, I just hope your hands weren't cold when you took her measurements. She's sensitive about things like that!
geep ( ) posted Sat, 30 November 2002 at 12:33 PM
I warmed the tape measure up first. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 1:39 PM
try seven inches down from where you measured her. ~wink~ hmmm, swaybacked, well actually, because of the posture ( or rather bad posture) of the majority of women, posette's swayack is an accurate portrayal of how a woman stands. seems good posture isn't being taught anymore, though it really doesn't become an issue until sexual awareness develops, since that is when most womens posture devolves into "butt out, chest out", creating lower back pain and a swayback. and to be fair, unless a guy has been in the military, he doesn't have good posture either. it's only in the military that posture is beingtaught any more.
Jaqui ( ) posted Sat, 30 November 2002 at 1:42 PM
the curve in posette's back is a fairly good approximation of a healthy spinal column, it's just that the muscles should be reducing the appearance of it. (I had to study posture, and the natural curve of theback, to reduce the effects of my scoliosis. )
geep ( ) posted Sat, 30 November 2002 at 2:41 PM
7" huh? Ok, I'll try that and see what I come up with. Thanks. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 30 November 2002 at 2:42 PM
Um, I guess I should ask Posette if that's ok first, doncha think? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 30 November 2002 at 3:41 PM
... ok. ;=] Is this the correct place to measure?
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 30 November 2002 at 3:44 PM
Do I need the "nudity" flag for a wireframe? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 3:58 PM
~lol~ okay, maybe an inch higher, so you actually measure around the buttocks as well. hmm, think maybe a nudity tag with a wireframe might be going a bit far.... but better safe than sorry. ~wink~
geep ( ) posted Sat, 30 November 2002 at 4:18 PM
Posettes you-know-what isn't very round in uh, well, er, um, ... ... that area. Now what do I do? cheers, dr geep <-------- now more confused than ever ;=|
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 4:22 PM
hmm, I've seen a post somewhere that said that Posette has more curvy figure than Vicky does. and it was from daz that it came from.
geep ( ) posted Sat, 30 November 2002 at 4:36 PM
.................................. nevermind. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 5:08 PM
~lol~ look at vicky, she is less curvy than posette.
Jaqui ( ) posted Sat, 30 November 2002 at 5:21 PM
um, how about...
shadownet ( ) posted Sat, 30 November 2002 at 5:28 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=895452
Heya, that's a result of too many spankings. You might try this: http://www.renderosity.com/messages.ez?Form.ShowMessage=895452
Jaqui ( ) posted Sat, 30 November 2002 at 5:35 PM
~rotflmao~
geep ( ) posted Sat, 30 November 2002 at 5:38 PM
Spankings???
Just what is it yur tryin' ta say there ma friend?
'Sides, ... I just though of that myself, also.
Ain't brains wunnerful?
Jaqui,
(I love that name - is it pronounced Jack'-ee)
(or Jah-kee'? - just curious)
' <------- that's supposed to be an accent mark
Thanks for the dialog (and the neat pic) and the info.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 30 November 2002 at 5:39 PM
... the "nudity" flag ............ ... or were you just workin' off mine? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
shadownet ( ) posted Sat, 30 November 2002 at 5:43 PM
Just trying to help. The guy who wrote the tutorial is a really sharp fellow, just thought it might benefit you to read up on what he had to say is all. Course, that is one point of view. You appear clearly engaged (or engrossed) in another. :O)
geep ( ) posted Sat, 30 November 2002 at 5:48 PM
one-track-mind one-track-mind one-track-mind one-track-mind
TWHAP
Ow!
Thanks, I needed that.
cheers,
dr geep <-------------------- has a one-track-mind
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 6:00 PM
hmm, dr. geep in this thread ... dr. geep wrote the tutorial... is it possible? is this really that same person?!?!? wow!!!!!!!!!!! ~lol~ (I love that name - is it pronounced Jack'-ee) works for me. ~g~ and working off the nudity tag that started this thread, since most are aware that nudity is in the thread now. ~g~.
geep ( ) posted Sat, 30 November 2002 at 6:16 PM
... in the eye of the beholder, n'est pas? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 6:31 PM
~l~ yup
Bobasaur ( ) posted Sat, 30 November 2002 at 7:23 PM
Only if you've got good eyes!
geep ( ) posted Sat, 30 November 2002 at 7:35 PM
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sat, 30 November 2002 at 7:54 PM
"plastique"?!?!? you put explosives in her bottom?!?!?!?!?!? you mean I guessed right at her hips being 36" down there? wow
geep ( ) posted Sat, 30 November 2002 at 10:39 PM
.... give or take a 1/4". Isn't 36-24-36 supposed to be ... well, perfect? But, I used MY scale so somebody could still debate .... Thanks ladies, for your input. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Jaqui ( ) posted Sun, 01 December 2002 at 1:02 AM
hmmm, no problem with the help, but I'm Stormrage's Husband. ~lmao~
geep ( ) posted Sun, 01 December 2002 at 7:49 AM
I know, but Carolly isn't ...
... and Stormrage isn't (I know you got the info from her)...
Ok, thanks everybody for the input.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Zenman53186 ( ) posted Sun, 01 December 2002 at 9:17 PM
Now, Doctor, are you going to apply these learning to Victoria? Curious minds want to know....
Jim Burton ( ) posted Mon, 02 December 2002 at 7:23 PM
When I was building the original Supermodel Vickie I did try and make her a specific set of measurements, namely 36-23-35, based on a height that I assumed was 5' 11". She is a lot taller than the Posette, and somewhat thinner, of course. I'd guess standard Vickie is more like 40-28-36, or there about.
hauksdottir ( ) posted Tue, 03 December 2002 at 4:46 AM
Definately female here. :) By the time I found an illo from a clothing catalog with the proper place to make measurements, you'd got her taped. Those measurements are only considered "perfect" because some ancient Grecian sculptors idealized them in marble. Most of us fall short of the perfection of Aphrodite and Artemis, which is good when you consider the fate of mortals who rivaled them in beauty. Carolly
bikermouse ( ) posted Tue, 03 December 2002 at 11:06 PM
sooo . . . what happened to them?
hauksdottir ( ) posted Wed, 04 December 2002 at 2:00 AM
Zeus... (in the form of a swan) raped Leda, (in the form of a bull) carried off Europa, (in the form of golden shaft of light or coins) impregnated Danae, etc. and etc.. Apollo chased Daphne and she got turned into a tree to escape him. As much as I like trees, turning into one ought to be a matter of desire not desperation. And poor Medusa! She was beautiful, and a virgin sworn to the service of a goddess, when a god (I'm forgetting which one) pounced upon her. She got cursed with the snakes by her jealous goddess so that no man's wandering eye would lightly fall that way again. Leaving her homeland and all known amenities, she fled with her sisters to a barren rock... and even there she wasn't safe from the gods because Aethena told Perseus to go there and behead her. Not good at all. A wart on the nose or knock knees would be easier to live with than the attention that too much beauty can bring.
bikermouse ( ) posted Wed, 04 December 2002 at 11:56 AM
hauksdottir, Of course you might also say that beauty is in the eye of the beholder and it's appreciation dependant on more than just physical attributes. Would Helen of Troy or Penelope be considered beautiful today? Perhaps not. In my opinion, the shallow 'ideals' most of us place on beauty today come from Hollywood rather than Classic Greek statues. To me, the most beautiful of people are those who can see the beauty in others. As I learn more about modelling and morphs I find that the Poser figures are too thin. (Roxanne is, of course, too far the other way.) I've known a couple of girls that are "wasp waisted" and they really weren't that much fun to be around as they didn't seem to have the energy to keep up with me walking or hiking or going off to explore "New Lands". Well, I've gotta go get some presents for friends. geep, I think 38C-26-36 is what I'd consider ideal. but as you probably read above, more to it than that - doncha know. cheers, - TJ
