Sat, Jan 25, 12:42 PM CST
Subject: Problem with SLOW loading time...
ookami ( ) posted Mon, 02 December 2002 at 11:03 PM ยท edited Sat, 25 January 2025 at 12:37 PM
My poser seems to be taking FOREVER to load. Sometimes up to 1 minute just to load up on a 2.4 with 1 GB running Windows XP. Any ideas what might be causing such a slow load time? Thanks! John
tasquah ( ) posted Mon, 02 December 2002 at 11:04 PM
What poser 4 or 5 ??
leather-guy ( ) posted Tue, 03 December 2002 at 12:07 AM
A lot depends on how large your texture folder is, and what shape it's in - I fixed a Poser Lockup problem once when I noticed my textures folder was taking up 700+Gigs on a 60Gig drive - ran disk utilities to repair the corrupted folder entries, then defragged, and the problem went away. Disk Diags & Defrags seem always to be a good idea when looking into a poser problem.
Spit ( ) posted Tue, 03 December 2002 at 12:50 AM
Mine takes about 45 seconds to open. Depends on the size of your Poser directories. I've currently got a total of about 10 gigs total in Poser. A clean install opens faster. On XP (maybe others, don't remember) subsequent opens are faster due to caching.
ookami ( ) posted Tue, 03 December 2002 at 6:27 AM
Hmmm This is with Poser 4. As far as space... I think I have about 25 GB or so in my Poser folder.... so maybe that's the problem. DOH! Not sure what I can start pruning... but maybe defragging is in order....
djuke ( ) posted Tue, 03 December 2002 at 7:42 AM
I have the same problem, but I still don't have any solution. BUT! Yesterday, I moved all my "readme" files, all my 3ds, obj etc.. to another harddrive. In other words, I cleaned my poser4 directory from all sort of "polution" and it seemed to helped a bit. The speed could be better thoug, but still it helped. So my advice is to strip any file that don't belong in the poser directory! Hope it helps you Djuke
djuke ( ) posted Tue, 03 December 2002 at 7:43 AM
Ohh, forgot this, I have poser pro...
Tirjasdyn ( ) posted Tue, 03 December 2002 at 2:29 PM
a whole minute? alert the media... If this is really such a problem, you might want to try correct reference(see free stuff) as this will make sure the files in poser are pointing in all the right directions, making it easier for poser to find stuff. Otherwise sitting quietly in your chair helps, so does getting up to get a drink.
Tirjasdyn
Spit ( ) posted Tue, 03 December 2002 at 3:24 PM
Correct reference has no affect on how long it takes Poser to open.
Tirjasdyn ( ) posted Tue, 03 December 2002 at 4:57 PM
I thought pro pack did a seach files simular to p5, that's what I remember it doing any in that case it might. My suggestion to sit tight, hold your breath or something still stands.
Tirjasdyn
Spit ( ) posted Tue, 03 December 2002 at 5:17 PM
Yeah, Poser goes through its directory, but it doesn't check references when it opens.
