Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
Wasnt expecting the 4th steph .... * chuckle * That's how corner mirrors work, y'know. Two reflective surfaces, three reflections. When I was experimenting with faked reflections in P4, I had to put in a little more effort and add that reflected reflection, also. Displacement shouldn't slow things down much, but reflections and dynamic hair can be killer. Cheer up, 5GHz machines will probably be available by this time next year.
But it's just default lights, default render settings, and smaller. It would take longer if I used premium settings. But still, two hours seems like an awfully long time.
I just ran my own timed test in Poser 5, using a similar scene and setup. It rendered in a little under three minutes in Production Mode with shadows, and I don't exactly have the most robust system on the planet.
Still using a Pentium 3-850MHz rig, 128MB RAM, Win98FE (for now).
A suggestion to all above, If you are using Hi Res texures, I'd recommend turning off the FireFly render option, Use texture filtering. This speeds up rendering times immensely. Buried deep in the following thread are several tips I provided over the weekend on setting up render options. Have at it and I hope these tips help you out with future rendering, -Brian
Soluble Hamster
The one, the only, dissolvable rodent.
