102 threads found!
Peggy_Walters | 0 | 191 |
(none)
Peggy_Walters | 7 | 248 | ||
Peggy_Walters | 8 | 333 | ||
Peggy_Walters | 5 | 109 | ||
Peggy_Walters | 7 | 598 | ||
Peggy_Walters | 16 | 918 | ||
Peggy_Walters | 2 | 289 | ||
Peggy_Walters | 31 | 1032 | ||
Peggy_Walters | 7 | 159 | ||
Peggy_Walters | 2 | 133 | ||
Peggy_Walters | 8 | 212 | ||
Peggy_Walters | 1 | 120 | ||
Peggy_Walters | 7 | 171 | ||
Peggy_Walters | 35 | 1134 | ||
Peggy_Walters | 5 | 198 |
2,247 comments found!
Hi PepBoy,
Not that I know of, but I do think that e-on's tech support has a way of logging onto a user's computer to fix problems. It cost money though. Best solution is to ask specific questions - i.e. are you getting an error message when installing?
Integrating with Max, that may be the tough part. I only use Infinite, so I could not help. Sometime it helps to post to the e-on registered user's forum and Cornucopia3D's forum too.
LVS - Where Learning is Fun!
Thread: The Plant Factory? | Forum: Vue
Thread: Working with Layers | Forum: Photoshop
As a newbie to Photoshop, can you recommend some good tutorials/books for working with layers?
Thread: Generation X Genesis Tutorial for Beginners (and not-so-beginners) {Warning: Nud | Forum: DAZ|Studio
Yes! Going the CR2 to GenX works. I finally created a character and had a nice icon to remind me what it was. Thank you!
I will have to try this way. Hope I will get better results. So far nothing but crashes or nothing happens...
I watched a video over at http://takoyakida.webs.com/videos/GenX_Tut.htm. When I click on the Accept button, GenX freezes. I can only click Cancel and no files are created.
Thread: Installing Vue 11 Infinite on Windows 8 | Forum: Vue
From the registered user forum:
Vue 11 hasn't been completely updated for Windows 8 as yet. So after you've installed your new Vue 11 Artist product, right-click on the program icon and select Properties. On the Properties dialog, select the Compatibility tab.
Set the first option, which is Compatibility mode, to run this program in compatibility mode for Windows 7. Vue should run just fine with that setting.
Cheers, Lee
Thread: Vue Freezes with the "Sea Plane" added | Forum: Vue
From the Vue registered users forum: I believe this issue has been identified thanks to your feedback and a fix is underway. It is an issue that occurs only for those who don't have the KronosFX module. Sorry for the inconvenience.
Thread: Vue 9 & Ecopainter 10 question | Forum: Vue
http://www.cornucopia3d.com/purchase.php?item_id=9101
EcoPainter Vue 9
Cornucopia has modules available from Vue 7 and up. Look in the store under Tools. The modules for Vue 9 start on page 3.
Thread: Vue 8 display problems | Forum: Vue
Check your Vue options does not have the Use paper box selected.
File, Options, Display tab.
Thread: Problem trying to upgrade to Vue 10 studio | Forum: Vue
Did you log into your e-on account and have the serial number sent to you? It could be that the new Vue 9 Studio serial is on your account.
Thread: Vue beginner question | Forum: Vue
You need the 3D import module and then there is a ton of free stuff for Vue. Using Frontier, anything you have in Poser or DAZ format can be imported, but really think about the import module.
Thread: Importing into vue | Forum: Vue
Send an e-mail to support@cornucopia3D.com. The product page shows Vue 9 all versions, so it should not have let you buy it if you don't have a registered copy of Vue 9.
Thread: Time to upgrade? | Forum: Vue
OK... Now I am feeling a bit rightous.
I had a really long post to answer this, but I decided not to even bother. Why waste my time.
When you click on the description for the products, it very clearly identifies what you are buying with a link to an even more detailed page with all the benifits of a subscription. If you didn't read the description, then tough luck. I mean, the product description before you add it to your cart says + Annual Subscription. Sheesh!!!
Vue 9 Complete - Download - Vue 8 Complete Upgrade + Annual Subscription
Save up to 50% on your next upgrade!
This products bundles a Vue license with a Product Subscription program.
With our Product Subscription system, and a small monthly payment, you can save up to 50% on the normal upgrade price of your next Vue upgrade, and you'll also be able to download the new version of Vue as soon as it's officially released!
By purchasing this product, you hereby accept the terms and conditions of the Product Subscription, program, and authorize Cornucopia3D to charge you the corresponding subscription monthly fee.
Click here for more information on Product Subscription.
This product can only be purchased with Visa or MasterCard. Paypal is not available as a payment option because of the automatic monthly renewal feature.
Your Vue 8 Complete serial number will be required during the order process.
This product ships with an electronic version of the user guide (PDF).
You might also consider adding the Official Printed Vue 9 Artist User Guide to your order!
Thread: Vue Classes at LVS Starting Soon! | Forum: Vue
