228 threads found!
Tiny | 20 | 513 | ||
Tiny | 7 | 149 | ||
Tiny | 0 | 148 |
(none)
Tiny | 16 | 455 | ||
Tiny | 16 | 433 | ||
Tiny | 8 | 255 | ||
Tiny | 2 | 91 | ||
Tiny | 11 | 202 | ||
Tiny | 0 | 88 |
(none)
Tiny | 4 | 88 | ||
Tiny | 13 | 205 | ||
Tiny | 26 | 346 | ||
Tiny | 4 | 206 | ||
Tiny | 3 | 163 | ||
Tiny | 0 | 43 |
(none)
1,256 comments found!
Thread: Poser 13 install error | Forum: Poser - OFFICIAL
hornet3d posted at 8:29 PM Sat, 8 April 2023 - #4461399Good thinking! 😊Tiny posted at 12:39 PM Sat, 8 April 2023 - #4461303It's my case, but not to avoid conflicts with UAC, just because I wanted that all Poser-related stuff (executables, runtimes, etc..) be on a dedicated, SSD drive, and to let Windows do its things on its drive: no mix no problemsYou are welcome. I do know that many users install Poser to a drive other than drive C just to avoid conflicts with Windows UAC.Update. 😊
I had to install on another drive and now it is working. Thank you for the advice. 😊
Furthermore, this lets me write Python scripts and drop them in one of the runtimes in a handy manner
Update. 😊
Thread: Hair "room" improvements in Poser 13? | Forum: Poser - OFFICIAL
hborre posted at 9:27 AM Fri, 24 March 2023 - #4459455
Poser 13 has not been released yet until March 30th, so no one really knows what actual features have been improved upon except the development team.Thank you. I figured if someone from the team could give a hint. Will wait until it is released and ask then. 👍😊
Thread: Export fbx Poser > Blender how avoid distorted mesh? | Forum: Blender
Thank you Lobo3433. I am using Poser 12 latest patch, Blender 3.4. Horse is the Hive Wire horse. I will find the Better Fbx and test it. Good advice. 😊
Thread: Hair to Poser figure in Blender = Invalid UV map... islands overlapping | Forum: Blender
Ok, good. Thank you. 😊
I'm sure I will be back with other questions so it is really good to know there is a friendly and helpful community.
Posting this in case someone else has same issue.
I was able to get it done following THIS tutorial and adding the horse texture after the hair was added.
No need to create new UV map and no errors. Am soooooo happy. 😊
Big thank you to everyone supporting and helping. Hugs.
Pic showing first, rough try for a dynamic mane created directly on the horse mesh. Horse with animations imported from Poser as Alembic file which kept all morphs.
Aha, I see. Makes sense.
I have not worked much with UV mapping so I simply thought the texture was it and it did not look as if anything was overlapping. See attached pic.
I will test making a "mane object" for each neck part, put hair on them and have them follow the animations. Should work right? :)
This is only part of the texture since one is not allowed to "redistribute" it. So this is not the UV map? If it is, could the pixels touching in some areas be considered overlapping?
Sorry for all the beginner questions. I do appreciate everyones input and guidance a lot. 😊
Yes, I know about that one but is it not possible to add hair directly on the horse mesh?
For example if I am to create and use a separate mesh for the horse mane how will that follow the animations? The horse neck has 3 bones+ the head.
If possible I would prefer to add hair straight on to the horse mesh. But....
The problem I am having is the existing horse UV map/ texture, imported and added on the horse, will not show up in UV editor.
Does that mean I have to create a new UV map in Blender including all the "cutting of the mesh" and such? Seem like waste of time since I have 24 different horses and breed already made which only need mane and tail in Blender. :)
More suggestions please. :)
Thread: Tutorial? Poser to Blender for morph targets and back. | Forum: Blender
Brilliant! Thank you ever so much it works now. > Happy dance <To allow the Blender forum to show, click on your name in the top right corner and click on settings. There will be a menu bar that starts with My Settings. In that click on forums and scroll down until you see Blender. Check that and scroll back up and hit the save changes button. You should see it when you go back to the forums.
Lobo3433 posted at 11:05 PM Tue, 28 February 2023 - #4457288
Thank you Lobo3433. The issue for me is when creating a new thread I don't get "Blender" as an option for which forum to post in. It's been awhile so I'm sure I'm missing something obvious. :)Tiny posted at 10:27 AM Tue, 28 February 2023 - #4457193
Sometimes issues with not being able to start a thread you might need to clear your internet cache and which browsers have you tried creating a thread with and if clearing cache does not help send me a site mail directly and I will let the admins know about your issuePlease forgive me for hijacking this thread but for some reason I can't start a new thread. Please advice anyone.
Thread: where is Poser 13 sdk for Vue 2014? | Forum: Vue
