1 threads found!
Capt_Nemo | 2 | 63 |
7 comments found!
Poserworld doesn't have dungarees for V3, but does for Matt and Maddie, Freak and M3. If you have Wardrobe Wizard, you're in business. Tracy
Thread: reduced resolution V3 | Forum: Poser - OFFICIAL
Kawecki - she's a doll! I make lower resolution versions of all my characters. You can save the face as an expression and it applies to the RR just fine. Same with the bodies. The lower poly count speeds things up a little - but when you're doing animation, a little time per frame sure saves a lot of time in the overall project. TV and DVD is such a low resolution medium to start with that the lower character resolution is hardly noticable. I'll post some pics in the next couple of days. Tracy
I do DVD resolution animation, and she (M3RR, too) looks great! Renders faster, too. DAZ has a tutorial on how to apply the morphs to her. I haven't tried Kawecki's nipples, though. Tracy
Thread: Dungarees for V3 | Forum: Poser - OFFICIAL
Try out this one: http://poserpros.daz3d.com/store/viewitem.php?selitem=6835&start=0&selcat=0&selsub=0 When doing a search, try also "jumper." Tracy
Thread: Poser 6 rendering animation? | Forum: Poser - OFFICIAL
I use the Microsoft MPEG 4 codecs which you can find at http://www.videohelp.com/tools?tool=ASF_Codec They're fast and compact and the video quality is great. I've dumped files using this codec at a 1500 rate only and they've compressed to DV/DVD without any noticable loss. There are also some lossless codecs that are great too - check out this one at http://www.videohelp.com/tools?tool=Alparysoft_Lossless_Video_Codec. There are other codecs for you to consider at http://www.videohelp.com/tools?s=6#6. Tracy
Thread: Who am I? | Forum: MarketPlace Showcase
Thread: Clothified Sheet - pull it without tearing it | Forum: Poser Technical
Thanks for the suggestion on 2. I'll try it this weekend. As for your suggestion on 1 and 3 - I've checked those boxes and the sheet still tears. I'm going to try to make some of the M3 and V3 parts invisible and see if that helps. TRACY
