2 threads found!
Niki | 2 | 172 | ||
Niki | 16 | 435 |
21 comments found!
Yes in the futurs plugins it will be a windows with tools. Like Get MAt from PZ2. MTL, PZ3, CR2 etc... I have to see Bit the first things we have to do is to reorganise the selections in C4D. Now is Selection 1 etc.. we look to make it compatible with the Imported OBJ files Like Selection 1 -> SkinBody etc.....
Thread: PZ3 texmap syntax question | Forum: Poser - OFFICIAL
Ok did youi use Poser 5 If yes is probably the cause of thoses fancy number I just look on my C++ stuff and yes is funny stuff in the file Try to just delete them after you made a copy of you PZ3 file
Thread: Poser c4d Plugin Problems | Forum: Poser - OFFICIAL
No the actual plugin is for still image. We do work on a new set's of plugin for animation, but this will be down in C4D R8 using Mocca. Those plug's will eliminate the Poser program. We get this desition just because Poser is a little bit limited in real anination. All will be base on V2 LoRes. Why ??? simple, the V2 LoRes can get Hi, very HiRTes thru the NURBS. All Morph wil be in two part. One will be the head base morph and an other expression, but i mean real expresion, like talking synch to the sound file in C4D. All taht in dolby surround. So we look with part of morph will be done is Our plug's and the par of Poser. Yes Poser will still be there, but we are working on it so hard to say all about. Sorry for english is not realy my language... IS Suisse Francais :)))))))))))
Thread: Very General Question...s | Forum: Poser - OFFICIAL
Hi We do brook all that, by making two free plugins for poser 3, 4 and 5, C4D 6, 7 and 8. Or lower not tested :( The CL plugin was to limited to me. Specialy the Poser 5. Look on some others thread here I put comment and the plugins you can get all for free at Mec4D on my gallery have fun Niki.
Yes I do get a lots of problems with the poser plugin. I why after all problems with Poser 5. We do our own plugins. Is two and is free on Mec4D on my gallery. Is not limite on memory usage, and all your Vic and Mic work as well, even V3 or all P5. We do this because I relly need some things that work... work fast take like 10 seconds to get your figures or less then 5 seconds to repose the figure. The plugin 2, will just copy the pose and don't touch all the texture and MAT, or even your own selection or MultiLayered Mat. Niki
Thread: Maps for Victoria III | Forum: Poser - OFFICIAL
Is not the question UV's map have nothings to do about the teextutre it self and the way they toke that picture do do the texture all, that to me, is what i call chocolat :(
Thread: v3 uv mapper issues on mac | Forum: Poser - OFFICIAL
use work to translate from rich file to text file or the oposite, it work I use Visual studio for all that is faster, but befort i'm was using word 6 or 2000 it should work also on a MAC !
Is more simple just get the UV's from DAZ use the UVmapper Load figure at runtime->geometry->Dazpoeple->Vic 3 then import the DAZ UV's MAP in it at runtime->Daz V3 uv's or some thinks like this then save the figure as the on you get from the daz people in the runtime folder, juste overwrtie the Daz one, it work, but first make a copy of the original one, I for get the name now
Thread: V3 clothing | Forum: Poser - OFFICIAL
Well i see you idea but i'm making comics so to do all thje poses that way will take to long. Is a good idea but if you just do a pinup one pose :o) I wil look to do that on C4d may work better and faster, thanks any way Niki
Thread: Poser 5 or V3 problems X | Forum: Poser - OFFICIAL
7 minutes ? that long, I do it for face all face and mouth and it takes like 30 secondes for both !!! is maybe some thinks else there... I cant say any about it , in Poser5 it lock ok but on my P4 PP is all ok
When you download it, and install it will check if you have to V3 model if not it dont install it that all, but is free on DAZ site...
Good is true, I dont get a dinner to poor for it, well I buy poser 5 so... so i just get a caffe, and ho well... No is lock sorry :o) Niki
For texture yes you can use all V2 just download the UV's on DAZ V3 site and get the UVmapper..- for clothes .. hum get the same problems, the bones structure is ok but not the size of it... Niki
Attached Link: http://store.daz3d.com/catalog/product.php?pidx=2102&paridx=0
Ok go here on the links, at the bottom is and UV V3 to V2 You also need the UV mapper is free too on http://www.uvmapper.com/ if you need help I'm there :o) NikiThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Thread: Beta version of new Poser to C4d R8 | Forum: Poser - OFFICIAL
