365 threads found!
PhilC | 2 | 62 | ||
PhilC | 11 | 436 | ||
PhilC | 3 | 184 | ||
PhilC | 8 | 442 | ||
PhilC | 7 | 266 | ||
PhilC | 28 | 760 | ||
PhilC | 16 | 487 | ||
PhilC | 2 | 564 | ||
PhilC | 10 | 874 | ||
PhilC | 3 | 82 | ||
PhilC | 3 | 96 | ||
PhilC | 5 | 231 | ||
PhilC | 11 | 350 | ||
PhilC | 11 | 348 | ||
PhilC | 9 | 149 |
7,929 comments found!
What steps are you taking to export? Starting with File > Export > Wavefront OBJ, what did you do then?
Thread: Cloth Room Cloth Types | Forum: Poser - OFFICIAL
A long while back I wrote a Cloth Room Presets script. It is available at ShareCG. Search for "Cloth Room Presets". Hope it helps.
Thread: Adding extra weld commands | Forum: Poser - OFFICIAL
Wardrobe Wizard has used additional weld commands for years. I doubt if anyone has noticed although they would have if the commands were not there.
Thread: Changing joiint blend angles etc | Forum: Poser Python Scripting
Thread: Animation How to cycle or copy paste frames? | Forum: New Poser Users Help
In the animation pallet: Left mouse down, drag to encompass frames to be copied. Cmd+C Use mouse to highlight section of animation to be copied to. Cmd+V
Thread: How do you edit and SAVE joins/bones in Poser 14 | Forum: New Poser Users Help
Thread: How to Install Objects/Characters Etc.? | Forum: New Poser Users Help
OK Use WinZip to extract the ZIP to a new folder, for the sake of this reply let's call the folder "My Poser Stuff". Just be sure you know where the folder is.
Next open Poser and look in the top right hand corner of the library panel for a button/icon "Add Library". Click on it and navigate to your "My Poser Stuff" folder. Select the folder, click the OK's.
Now on the other side of the library pallet, next to "Show Library" click on the little down arrow. Select "My Poser Stuff" which will probably be at the bottom of the list.
Review the various sections of the library for your stuff.
You can install correctly formatted zips from within Poser. Go to the "Content" tab and click on the "Install from ZIP archive" button.
Information regarding the Poser libraries and how to use them is found in the manual. For an overview go to the Poser menu Window > Quick Start > Library.
When installing content make a note of where you are installing it to then ensure that you have that content library added to your Poser library panel.
Which Poser content library did you install them to? Is that Poser content library currently added to your Poser library panel?
Thread: Using a Python script to move geometry vertexes | Forum: Poser Python Scripting
Something appears to not be working any more. Your script looks to be correct. I ran UnimeshDemo.py on the P4 nude male in Poser 2014 and whereas a vertex in his thigh got displaced in previous versions it is no longer apparent now.
I do not know if it is due to various Poser updates or Windows updates but I've found that a number of scripts that worked fine for years now no longer do so.
Thread: The poser.ProcessCommand() calls | Forum: Poser Python Scripting
Thread: Move camera too close, character disappears. | Forum: New Poser Users Help
Thread: OT: Steve Cox UV Mapper - Anyone use it? | Forum: Poser - OFFICIAL
Thread: Help Needed - Exporting a figure to OBJ | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
