9 threads found!
Advisories: nudity
ProPose001 | 2 | 114 | |
1 reply with content advisory
ProPose001 | 6 | 396 | |
Advisories: nudity
ProPose001 | 9 | 545 | |
ProPose001 | 12 | 771 | |
ProPose001 | 0 | 75 |
(none)
5 replies with content advisory
ProPose001 | 37 | 4028 | |
ProPose001 | 9 | 167 | ||
ProPose001 | 6 | 245 | ||
ProPose001 | 10 | 354 |
217 comments found!
So am I, I'm also grateful that I can post what motivates me, and I'd post more but...I guess there's a lot more to Carrara than rendering nudes and people might get tired of that.
Thread: the hanging by a thread render thread | Forum: Carrara
Thread: Genesis 8.1 in Carrara | Forum: Carrara
This is Lyra by Bluejaunte. She's actually a G8F figure but I ended up using G8.1F because of the toe issue.
Thread: Genesis 3 in Carrara | Forum: Carrara
Rural Chateau 1 and 2 is a really nice set, and it comes with a poser version which works perfectly, the DAZ version not so much.
Thread: Genesis 8 in Carrara | Forum: Carrara
New Year. New Project.
Happy New Year Folks.
Got myself some new toys for Christmas.
D.Master stuff from Daz3D. Picked up the Auto Face Enhancer Bundle for G8F (on sale). Plus a few other items for this character.
AFE allows for some HD morphs in Carrara. AFE is a GeoGraft Face for G8F, and as such, the UV's get messed up in Carrara the same as it does for the Anatomical Elements for G8F. My work-around is to merge the grafts into the main figure, and the result is... well you can see in the screenshot.
Initial test are promising, as in it works in Carrara 8.5 Pro. I did run into the "Toe Issue" with the AmiraHD figure, identical to the V8 figure.
Here's a screenshot
If you guts are interested in the 'Making of Amira' I'll be glad to elaborate. I also fixed the Toe Issue in the Veronica for G8Fpreset by Misty. I'm sure She'll approve, and I'm willing to share if interested.
Thanks for looking
Thread: Geo Graft | Forum: DAZ|Studio
Genesis 8 Female this time
A 'Merged' Figure. G8F with LY Every Girl, merged the gens and Colm Jacksons Fiber Brows and Lashes. Also using Laticis Imagery Petite Pubic Hair, which is also merged into the Figure
Need some hair on her head
Thread: Genesis 2 in Carrara | Forum: Carrara
For the next few images, Same G2F, same skin, same Layton Hair, but different scene. I started this exercise after watching a utube video by Jay featuring Colm Jackson talking about Rembrandt lighting. That's what the above image was supposed to illustrate, but I mangled it completely cause I moved some of the lights around and adjusted the levels. In the video, they are using Daz Studio with Iray, and the results are awesome with the Render Studio light setup by Colm. So after butchering my initial attempt, (the image above) using the Render Studio light set, I started fresh using Phil's Portrait Studio (Carrara content) instead. This is what I came up with so far.
Face Camera
Upper Body Camera
Still stuck on G2F
This is Quinn by Saiyaness For G2F. The light set I used here is by PhilW from his Portrait Studio kit for Carrara. Anyways, I'm playing around with an 8k texture set for G2F I found online.
Thread: Archives? FAQ Tuts for Making Ground Planes from Grayscale? | Forum: Carrara
Not aware of any tutorials on the subject, but.....
Yes, Carrara can use Grayscale images to create terrains. Start with an empty scene, then drag in a Terrain object via the tool icons or front the Insert Menu drop-down.
That will get you into the terrain editor, from where you have lots of options in creating a terrain using the tools in the editor. If you're not comfortable with the painting tools of the editor the you can Clear the canvas using the 'Clear' button and 'Import' a height map or displacement map available from numerous sources on the Web to generate a terrain, real world or otherwise. First thing I would do though, is READ the MANUAL. I know the documentation sucks, but even the Carrara 6 Manual that comes with Carrara 8 has a wealth of info that will help
