27 threads found!
STRAFE52 | 1 | 37 | ||
STRAFE52 | 8 | 230 | ||
STRAFE52 | 3 | 105 | ||
STRAFE52 | 5 | 122 | ||
STRAFE52 | 10 | 240 | ||
STRAFE52 | 16 | 314 | ||
STRAFE52 | 1 | 43 | ||
STRAFE52 | 3 | 125 | ||
STRAFE52 | 5 | 118 | ||
STRAFE52 | 12 | 294 | ||
STRAFE52 | 2 | 82 | ||
STRAFE52 | 3 | 156 | ||
STRAFE52 | 6 | 173 | ||
STRAFE52 | 3 | 83 | ||
STRAFE52 | 2 | 57 |
8 comments found!
Thread: Posing Issues | Forum: Poser - OFFICIAL
Thread: Speeding up parameter dials | Forum: Poser - OFFICIAL
I'm using a Radeon x1950. The system is fine but I was thinking the display adapter might need to be swapped out. What do you think?
Thanks for that tip wimvdb. It worked great. It's still a bit of a hastle switching between wireframe to Bounding Boxes but it sped up the process ten fold.
Thread: Poser Pro 2010 Problem | Forum: Poser - OFFICIAL
Right now with everything still the same:
P:Program FilesSmith MicroPoser Pro 2010
I opted for P:Program Files
P:Program FilesSmith MicroPoser Pro 2010. But I just tried to install V4 to this path again And I chose Poser (All Files) when asked for the target application and I got a message stating that "When used with Poser TM, "Victoria 4.2 Base" must be installed to the same directory as the application executable; due to restrictions on support file locations."
No, how do I do That? Is it neccessary?
I originally ran it on C: and it did the same thing, then I put it on an external drive and the same thing happened again.
I,m using Windows 7 and it is on an external harddrive (P: to be exact). I didn't realize there was a problem until I read your posting. Thanks.
Thread: V3 Question | Forum: Poser - OFFICIAL
Thanks for your response. The message I get is Error-Warning: Cannot open Runtimelibrariespose!V3ExpressionsINLBlink Left.pz3. This is the same message I get countless times, except with "Blink Left" being a different expression. I hope this helps.
