5 threads found!
TeamSchmidt | 4 | 221 | ||
TeamSchmidt | 3 | 198 | ||
TeamSchmidt | 3 | 383 | ||
TeamSchmidt | 13 | 3162 | ||
TeamSchmidt | 1 | 45 |
14 comments found!
hborre posted at 8:54AM Sun, 13 December 2020 - #4406802
The current and final version of Poser 11 is 11.3.818. Be aware, the naming convention has changed, Poser 11 Pro is no longer being used. It is now Poser 11 and as RedPhantom posted, you will need to upgrade your software with the Bondware version. The download can be found here: Posersoftware.com. You will require the serial number to validate your license. Please see my reply to RedPhantom
Thread: Unable to connect to licensing server | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
RedPhantom posted at 8:51AM Sun, 13 December 2020 - #4406796
Have you upgraded to the Bondware version? Or are you still using SmithMicro's version. SM closed their servers so everyone needed to upgrade. If you already upgraded, you might want to contact support I am using the latest bondware version of Poser 11. I figured it out! My firewall (tiny firewall) was blocking the connection even though I set it to always allow. So it has been uninstalled and problem resolved.
Thread: download reset request | Forum: MarketPlace Customers
Thank you! Now if I can just get PP 11 to work, or Poser 12 for that matter. Both give me an error message that reads as follows " unable to connect to licensing ser, you must be connected to the internet to use Poser" I have tried uninstalling, reinstalling, re-downloading and fresh install, nothing has worked. I am including a screenshot of the message
Thread: PLEASE HELP!! Dark preview window | Forum: DAZ|Studio
Okay I don't understand what happened but I went to my settings in interface to match yours I looked at my hardware capabilities where you showed me to look for it and my graphics card supports it all but I changed my settings to match yours and I cleared the scene started a new scene loaded gen 8 and boom she loaded with textures so it must have been something set up in the tab that you told me to look at that was causing the issue weird but thank you so much for helping me figure it out ?
Here are the screen shots of what happens when I load Gen8 into a scene after opening Daz. Note in the 1st one you can see that preview lights are on
Yes I can if you can give me a few because my poor little MacBook pro laptop is pretty hot right now from trying to do a render earlier so I'm letting her cool off before I do anything else but I will definitely upload a couple of screenshots for you and hopefully that will help figure out what's going on ?
I do have the preview lights on and I still can't see textures when texture shaded is chosen
Yes I did try applying different textures to the items that were in the scene and I still got a black screen apparently it's because I needed to have it set instead of to texture shaded I needed to have it on Nvidia Iray because once I did that then my texture showed up but like I stated before I have not used studio since Daz 3 so back then you clicked on that little globe and you switched it to texture shaded if you wanted to see the textures in real time ?. But I appreciate the effort in trying to help me figure it out ?
Okay I double-checked the viewport little thingy that you were saying was on cartoon mode and it's actually on texture shaded and I moved the spotlight like you suggested but now I instead of having a black everything I have a gray everything no textures are loading whatsoever
Thread: I heard there was a way to make injection poses in poser 11 without needing | Forum: Poser - OFFICIAL
Are morph injection files made this way in PP 11 able to be sold? Like do they contain copyrighted morph data if you use the V4 ++ dial morphs to create a custom morph for example?
Thread: Genesis 2 Female UV Maps issue | Forum: DAZ|Studio
I would try copying the runtime folder of the item in question to your desktop, then try manually loading it from there. Sometimes Poser and Daz will grab the wrong texture files if they have a similar names as another item. I have run into the issue alot, especially with Poser.
Thread: Which is the most realistic hair for V4? | Forum: DAZ|Studio
Thread: More Retro hairstyles please! | Forum: The MarketPlace Wishing Well
Awesome!!! I am only a beginner modeler right now and just starting to contemplate doing hair, hopefully some of the hair greats come up with some!
