29 threads found!
Thelby | 2 | 464 | ||
Thelby | 2 | 175 | ||
Thelby | 7 | 321 | ||
Thelby | 2 | 131 | ||
Thelby | 9 | 399 | ||
Thelby | 5 | 213 | ||
Thelby | 4 | 1837 | ||
Thelby | 17 | 381 | ||
Thelby | 4 | 253 | ||
Thelby | 37 | 1728 | ||
Thelby | 9 | 223 | ||
Thelby | 3 | 1473 | ||
Thelby | 52 | 1557 | |
Thelby | 2 | 133 | ||
Thelby | 2 | 102 |
635 comments found!
As good as Terragen is, it is No Vue! It doesn't seem to be able to handle the amount of different content that Vue does and/or as easily. I have used both for years and while Terragen has come so very far, I have yet to produce an interior scene worthy of that Vue can with little effort. Terragen with the last iteration may have surpassed Vue ability for Environment capabilities, it still can not handle 200 or 300 different objects in one scene. Not even with my super powerhouse computer. This will probably garner some negative attention, but all you have to do is go to the Vue and the Terragen Gallery and see for yourself.
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
Thread: e-on's website is back up!! | Forum: Vue
I had to Re-Sign Up because they erased my old account.
I would rather
Thread: Carrara and OTF Fonts | Forum: Carrara
Thank You Misty! I will look for them.
I would rather
Thread: Is this the Carrara forum? | Forum: Carrara
Thanks, Wendy.
I would rather
Since Mark left, who is Carrara Moderator now?
I would rather
Thread: What version of Photoshop is everyone using? | Forum: Photoshop
PS7 and PS-CS5 Extended. I keep PS7 around for couple of now obsolete features that allow me to add bump to photos.
I would rather
Thread: Does Vue 2015 (Complete) work with Windows 10? | Forum: Vue
decadence posted at 3:05AM Fri, 13 May 2016 - #4253512
I upgraded my PC (new) its a monster machine with windows 10 pro. Also just bought Vue Complete. It seems to work fine. However before shelling out more money I wanted to use Vue with Poser 6 but its doesn't import. Has anybody imported poser 6 into Vue 2015 ?? Does Poser 11 work on Vue 2015 (Complete)?
What are the specs of your new machine Decadence?
To answer the Vue question; I upgraded as well to Win 10 and when I open Vue it says
"**Warning: this version of Vue is not designed to run under this operating system **", but it still runs just fine.
I would rather
Thread: My Final Full Frame Animation? Cyberpunk Dystopia Episode 19. On Youtube. | Forum: Carrara
Nice work on this. I am curious as to what type of computer and the computer specs you rendered this on? What frame rate you rendered this at, 24FPS or 30FPS? How long it took to render? Cheers and you have a new sub at youtube.
I would rather
Thread: Black Areas in Render | Forum: Poser - OFFICIAL
This needs to be in the POSER Forum. They will probably know what to do with it.
I would rather
Thread: E-bots Are Back In Business! | Forum: Community Center
In the past you could pick which notifications via E-Bot you received on the people you follow. I have a hundred or two that I follow, but I do not want E-Bot Notifications on EVERY One of Them. Can I pick the ones I want to receive notifications on or will I need to Cancel Notifications all together???
I would rather
Thread: I thought render to disk was supposed to be fast. | Forum: Bryce
XP Pro 64 could be a small part of the problem as it is Much slower than any 64 bit version of Win 7.Â
I turned my old XP Dual Core into a storage device with 8 HDDs, because it still works but was SO Much slower  at rendering than my Win 7 machines.Â
I would rather
Thread: Cylon Basestar done | Forum: Carrara
Cool Modeling, Pho Shizzle!!!
I would rather
Thread: How to do this? | Forum: Photoshop
The lightning effect in the first image can be faked by brushes or my favorite "After Effects" to get a clean lighted and glow in the clouds.
Lovely pics!
I would rather
Thread: Carrara 8.5 Beta | Forum: Carrara
Personally I don't download nor install Betas. The term 'BETA' in itself means it is only temporary and will be replaced by the permanent version at a later date. But I most admit I have not heard of a BETA with a Temporary Serial Number.
I would rather
Thread: Duplicated objects always offset, despite setting | Forum: Vue
If you have not found it already, here is the answer to your question; "What boxes"?.
I would rather
Thread: Vue alternatives? | Forum: Vue
