211 threads found!
Tomsde | 5 | 106 | ||
Tomsde | 24 | 811 | ||
Tomsde | 10 | 1226 | ||
Tomsde | 21 | 10987 | ||
Tomsde | 3 | 244 | ||
Tomsde | 5 | 542 | ||
Tomsde | 11 | 640 | ||
Tomsde | 8 | 608 | ||
Tomsde | 6 | 337 | ||
Tomsde | 11 | 197 | ||
Tomsde | 10 | 201 | ||
Tomsde | 3 | 70 | ||
Tomsde | 35 | 537 | ||
Tomsde | 4 | 120 | ||
Tomsde | 24 | 764 |
1,263 comments found!
They're definitely a different default light set then was in Poser 10. I will be replacing them with something else a soon as I know what set I prefer. I wish Poser 11 had a set off light especially for Superfly available.
I assume that if I hide the guides that the construct will still interact with the lights even though it's not visible in the scene. Is that correct?
Thread: Background Problems | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thank you Poser Pro 11 is turning my hair while. I've not had so many problems since Poser 5.
Thread: The Construct | Forum: Poser - OFFICIAL
Can you explain how this is used as a light source? Does it become an OBL then? How do you adjust the light emission and us it similar to IBLs then?
Thank you @dlfurman for the videos. I wish someone would create more outdoor environments for Poser. I dabbled with Vue and Carrara to try to accomplish this. So if I want to use the actual Terradome with Poser 11, would I have to hide the Construct first by turning off guides?
So Superfly renders will cast shadows as long as the construct is in place? So I can place my scene in the construct, like a room and I'll get shadows.
So I'm not getting it, I'll have to watch the video--do I need the construct to get better Superfly rendering. I know you can't use IBLs with it--but you can if you use the Firefly rendering engine. Don't want to see the Construct in my images. I would like shadows on the ground plane but not the dome. If you try to change the background and foreground colors with the construct, the figures look like they are floating in air and there are no shadows. It's very confusing. I do have Terradome. I hadn't figured out how to delete the construct, because as I said previously I haven't been able to find it on the list of objects in the scene.
Thread: Conforming Clothing Seems Not to Work Properly in Poser 11.1 | Forum: Poser - OFFICIAL
@WandW I checked those items on the figures parameters and the clothings--is that wrong. Sometimes it works, sometimes it doesn't Do I need to just check it on the figure body actor only?
@operaguy thanks that works, in the past morphing conforming clothing just automatically followed the figure morphs.
It had seemed to be less of a problem in Daz Studio, which I don't Luke as much as Poser unfortunately.
Thread: Poser 10 VS Poser 11 | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Hazy Eyes and Background Noise | Forum: Poser - OFFICIAL
Thanks for your answers the GC setting aren't seeming to help with the issue unfortunately. I don't know why Firefly doesn't work like the legacy version did from prior builds. Is it because of the way Poser 11 handles textures that's the issue?
I have a lot of odd figures; can anyone give me any insights into what setting I need to adjust to get the eyes right if I'm using an unsupported figure?
Thread: Can't Install New Content | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
I've unfortunately installed certain content that the vendors insisted had to be in other versions of Poser's main runtime. So I had installed a lot of stuff to both Poser 7 and Pro 2012's runtimes. The content still works fine and so that was bull. So I have a lot of redundant models because it would be difficult to track down all that content and reinstall it. I thought of I put Poser Pro 11s extra content in that Downloads then I could just move offer that folder with a new name. So thou think I'd be better off just creating a new library for this stuff instead? I specifically mean content for Paul. I don't want to keep taking up all that disk space unnecessarily.
How do I fix the settings for the eyes so they look clear? I don't know why Firefly Renders don't look the same as in earlier versions of Poser.
