7 threads found!
VacuousSapient | 13 | 1173 | ||
VacuousSapient | 5 | 85 | ||
VacuousSapient | 33 | 694 | ||
VacuousSapient | 0 | 24 |
(none)
VacuousSapient | 6 | 119 | ||
VacuousSapient | 4 | 79 | ||
VacuousSapient | 5 | 142 |
22 comments found!
Thread: Poser 6 Glass Figure.... again | Forum: Poser - OFFICIAL
Yes, that is not a problem. However, there are no object parameters for teeth, gums, etc... in the properties configuration for making them invisible.
Thread: Render Wireframe in P6 | Forum: Poser - OFFICIAL
I attempted the above directions to render a wireframe model and all I am getting is a model (no wireframe) in a png format. Is there something else I can check? Thanks,
Thread: Basic question about grouping objects | Forum: Poser - OFFICIAL
When I attempted to parent the hair to the head, the hair repositioned itself somewhere else on the stage. It changed position and went down by the feet. Strange....
Thread: To Postwork or not to Postwork | Forum: Poser - OFFICIAL
Thread: Transparent Glass Figure | Forum: Poser - OFFICIAL
I have a challenge. I have managed to get (for the most part) what it is I am looking for in the way of a glass rendered figure. I might add with the help of all you who contributed to this thread. However... When I export or render to a png file the image is not right. It is solid and does not represent glass at all. I get a better export/render when there is an object (say a square with a design(sky)) behind the glass figure. However, when this is exported to a png (image) file the figure and the background object are one bitmap. I need the figure to stand alone. I am wanting to export the figure into Fireworks and later into a Flash movie. So it is important that it be the single figure. I hope this makes sense. Thanks,
I understand that. I probably asked that question wrong. I would like a figure out of glass. In thinking about that what would a human figure look like if they were glass? Would we be able to see the lips, eyes, etc...? As in a transparent outline? Just thinking through it...
Another question I have in attempting this. In setting up the nodes should all material (eyes, teeth, etc...) be the same? Thanks,
Ajax, Are you saying that Refraction, Reflection and Diffuse Values all/combined should equal 1.? Thanks,
Fazzel, Looking through your nodes above I was under the impression that the Reflection and Refraction values had to add up to one, combined. Thanks
