11 threads found!
amy_aimei | 3 | 705 | ||
amy_aimei | 12 | 1889 | ||
amy_aimei | 16 | 549 | ||
amy_aimei | 15 | 748 | ||
amy_aimei | 75 | 3162 | |
amy_aimei | 47 | 1673 | ||
amy_aimei | 2 | 227 | ||
amy_aimei | 5 | 517 | ||
amy_aimei | 7 | 315 | ||
amy_aimei | 0 | 92 |
(none)
amy_aimei | 2 | 409 |
204 comments found!
Quote - I'm having a play with Antonia in Blender - she's very nice, willing to accomodate me even there.ย
Are you able to migrate the bone system of Antonia to Blender? ย I'm thinking of moving Antonia to Blender too.
Thread: What is the best cr2 editor? | Forum: Poser - OFFICIAL
Quote - Notepad++?
*I just took a look at it. You can select and paste columns. All of the morph deltas are open, but I can hide them. Once that's done, this should do the trick. Thanks.
I'm using Notepad++ too. ย I setup my own "User Define Langauge" for "Poser". ย If you are interested, you can download it fromย https://sites.google.com/site/amyaimei/notepad/poser.xml
To import the settings to Notepad++:
Select View menu from the menu bar.
Select User Defined Dialogue... from the View menu.
At the User Defined Language Window, click the "Import..." button, then browse to the poser.xml, click OK.
Thread: Antonia - Opinions? | Forum: Poser - OFFICIAL
I just found some new expresssions for Antonia. ย http://www.sharecg.com/v/63485/browse/11/Poser/98-Expressions-for-Antonia-Standard
Thread: error parenting eyes to a mesh | Forum: Blender
I would like to suggest that you use the eyeball as the parent of all parts of the eye, then make the body as the parent of the eyeball. ย It should solve your problem.
Thread: Poserplace? | Forum: Poser - OFFICIAL
I got there but there is no activity in the forum since April, 2012. ย Am I get into the cached pages?
Quote - Well, the problem is not at Poser Place. It's whatever is between you and it.
All the best.
LROG
Could you get the IPv4 address of Poser Place?
This is what I got at my location:ย Unable to resolve hostname poserplace.phantom3d.net to IP address.
Thread: Correct settings for DS4 to obj to blender and back? | Forum: Blender
I can't connect to it too. ย I tried to ask someone in UK to connect there, it failed too. ย I think the issue is global!
@Cage, as I know, most of your stuff are hosted there. ย Do you have backup?
Hi Oom,
It sounds like you have found the best way to export/import mesh to/from DAZ Studio and Blender. ย Could you share it? ย The method I used is old, I would like to try some new methods.
Amy
Steps to export body part:
Hide everything in the scene of DAZ Studio.
Select the body part to be morphed and make it visible.
Export to OBJ format using default setting for Poser.
Hi Oom,
I just realized that you have read the "Making a face morph for genesis" ย The import/export technique there works with DAZ Studio 4 only. ย It will not work for Poser because dsf is a DAZ Studio file format.ย
Using OBJ import/export is the known working option for Poser<->Blender.
To export, select the obj, then use the File -> Export -> Wavefront (.obj) with the settings shown in the picture to export your morphed mesh.
I did that since Blender 2.4x. ย Thanks ideasman42 to make this happen. ย Seeย http://blenderartists.org/forum/archive/index.php/t-87473.htmlย for details.
The button "Morph Target" now take a generic name "keep vertex order"
Use the File -> Import -> Wavefront (.obj) with the settings shown in the picture to import your mesh.
Thread: Obiwan-Kenobi Attack of the Clones | Forum: Poser - OFFICIAL
Thread: Cycles eye shaders | Forum: Blender
