11 threads found!
danb | 4 | 88 | ||
danb | 10 | 186 | ||
danb | 7 | 115 | ||
danb | 4 | 81 | ||
danb | 6 | 138 | ||
danb | 4 | 146 | ||
danb | 7 | 117 | ||
danb | 36 | 588 | ||
danb | 4 | 86 | ||
danb | 11 | 193 | ||
danb | 13 | 239 |
38 comments found!
Hi Kuroyumo, yes i am up to a dastardly deed, but i cannot reveal my secret in public. Is there a PM here on renderosity? If not you can reach me at danb on cgtalk.com.
BTW, your plugin is awesome!!
Ashley, i am using 10.5 c4d.
Thread: InterPoserPro related. How to merge layers in Poser 7? | Forum: Poser - OFFICIAL
Oh i was afraid that this would happen. Its really too bad layers can't be merged.
I'm working with another artist, that i think already talked to you about this topic, and we both looked through the manuals and internet and still cannot find anything about merging layers to one single layer.
At the moment we can import only the base layer of animation into c4d through interposer pro.
What we are trying to do is animate a pose, then some lip sync, then another pose and then some walk designer animation. We are unsuccesful at doing this.
The problem is that if we keep the walk designer animation on the base layer we cannot have the walk designer start further down the timeline after the last pose. Walk designer always starts the walk on the first frame. Everytime i tried to change the keyframe start and stop point, i would get an error message of "time range incorrect".
Although if one puts the walk designer aniamtion on a seperate layer, that animation can be moved around without a problem.
Have you ever had the problem i described above about the walk designer only being able to start on the first frame?
Thread: Backround movie for rotoscoping? | Forum: Poser - OFFICIAL
Which movie format should i be using? I tried .mov with animation and sorenson codecs but got the message "Cannot load not enough memory". The file is only 4mb.
Any ideas?
Thread: Interposer Ltd. only loads 8 frames in c4d? | Forum: Poser - OFFICIAL
Ok that's good to know. If i purchase the interposer ltd. will i be able to import more frames?
Thread: InterPoser Pro to .fbx (filmbox) format? Poser to EIAS? | Forum: Poser - OFFICIAL
Ok thank you. I will try those suggestions. No problem about the bones. Hopefully D|S will save the day.
I am trying to export animations from D|S using .fbx. I hope i can figure out how to do that.
Any idea why i can't import my poser 7 scenes into Daz/3D? Does it support poser 7? I didn't check. :(
Thank you. Do you have a time table for when the interposer object to bones may be released? Its too bad i missed that special for Daz/3d. Maybe $100.00 is still not too expensive.
Thread: Copying Animation? | Forum: Poser - OFFICIAL
Oh good idea. How do i do that? :) I'm not savvy with poser aniamtion, pose, etc. :) Usually animate in c4d.
Thread: Why is my neck ripping from my body? | Forum: Poser - OFFICIAL
Hmm. Ok i did export the figure from my modelling program, c4d. It contained seperate objects like eyes and teeth. When i exported them those seperate objects became one object.
When i imported and grouped using the group tool they then showed up in the grouping list drop down. I just couldn't figure out how to assign bones to those groups. How do i attach the eye bones to each seperate eye group?
As of now i don't have any morphs on the figure. I don't know how to do that yet. Althought when i jump back and forth from Pose to Setup room, i get a dialog about morphs. Why is that? Is it because i used the Kate rig?
Thread: Interposer Pro .obj import, and other ?'s | Forum: Poser - OFFICIAL
