14 threads found!
dave3 | 7 | 196 | ||
dave3 | 7 | 154 | ||
dave3 | 2 | 60 | ||
dave3 | 6 | 117 | ||
dave3 | 6 | 283 | ||
dave3 | 2 | 114 | ||
dave3 | 3 | 67 | ||
dave3 | 16 | 213 | ||
dave3 | 2 | 60 | ||
dave3 | 3 | 89 | ||
dave3 | 2 | 93 | ||
dave3 | 1 | 58 | ||
dave3 | 7 | 740 | ||
dave3 | 2 | 16 |
52 comments found!
Thread: Posted a question in Amapi forum about A7 that came w/ Carrara 4 | Forum: Carrara
Well THAT'S reassuring! ;-) Thanks for letting me know -- at least I don't feel like a complete idiot now...
Thread: Problems with homemade dynamic clothing | Forum: Poser - OFFICIAL
Sorry about the delay in responding -- was away from my computer for the weekend. The answer to that would be yes -- I didn't realize that could cause problems. I'll look out for that in the future. Thanks!
Thanks for the tip, but I tried that. It doesn't crash, it just stops calculating. The cloth will run up to the frame where it stopped calculating. I think it does have something to do with the complexity of the mesh -- I tried making a simpler mesh and it ran fine. I guess I'll just have to scale back my ambitions!
It could be -- there are a lot of folds in the object. I didn't save the file so it would take me a while to come up with an image, but it does kind of bunch up. Is there a way to prevent this? Nothing in the mesh intersects itself or the figure, by the way; just a lot of folds...
Thanks for the reply -- that's what I found as well. However, no scaling seems to occur when I type a number in the export scale factor box. In A6, I had no trouble with this; type the number, scaling happens. I thought maybe there was something else I had to have turned on or disabled to make the scaling happen -- and also, this is just labeled EXPORT scale factor, which makes me wonder about IMPORT scale factor. I'm finding this program to be very difficult. I could work so easily in A6, but this version seems to fight me at every step! Any further help would be appreciated...
Thread: Using the same external obj multiple times in figures/props | Forum: Poser Technical
Thread: ERC -- What am I doing wrong? | Forum: Poser Technical
Well, I'm glad to be in such rarified company! While we're at it, maybe I can impose on you for some more advice. I have a hatch on my spaceship with two door panels that slide open. The door panels are named "airlock 1" and "airlock 2." I have rigged the ERC so that airlock 2 slides open when you open airlock 1; what I was wondering was if there was a way to show only "airlock 1" in the body parts list, and maybe make it show up only as "Airlock." And for that matter, if there's a way to make the "Translation X" dial show up as "Open" instead. I'd appreciate any insight you might have. Thanks!
Wow -- thanks for the prompt reply! Thanks for the figure-naming info -- that will help a lot. As for the rotation, I figured out my problem there -- I was referring to the channel as "rotateX xrot" instead of just "xrot." I changed it and it worked like a charm. Again, I really appreciate the help!
Thread: For the animation gurus... | Forum: Carrara
Can you make a spline object and animate that? You at least can use the bezier curves instead of using bones or endless linked segments...
Thread: initials | Forum: Carrara
I haven't used it yet, but HDRI is a Carrara 3 feature, and I believe it is a 'scene: background' option...
Thread: Differnce between Carrara1.1 and 2? | Forum: Carrara
Not only is version 2 more stable, it has additional features, like bones and global illumination. Get it, then upgrade to 3; or go straight to three. The beta is terrific -- the real thing should be great!
Thread: Carrara 3 interface improvements. | Forum: Carrara
I have to second Graviton's comments. The whole thing is just... better. And I think they were extremely smart to 'pre-release' it first as a beta. With all the flack other softwares have been getting upon release, it was a very clever move -- the endusers get a reduced price to test it. However, where the other softwares might not have lived up to the hype on final release, Carrara 3 exceeds expectations while still in beta! Thanks Eovia, and if anyone has any doubts about whether the upgrade is worth it, it totally is!
Thread: The Glow Channel | Forum: Carrara
If the glow isn't too bright, it will be washed out in the light areas, but still show in the shadows. For example, if you use a 50% value of the color in the glow channel, the light at 100% should overpower it...
