40 threads found!
graylensman | 7 | 315 | ||
graylensman | 10 | 245 | ||
graylensman | 6 | 136 | ||
graylensman | 4 | 80 | ||
graylensman | 1 | 82 | ||
graylensman | 3 | 141 | ||
graylensman | 7 | 171 | ||
graylensman | 2 | 69 | ||
graylensman | 5 | 113 | ||
graylensman | 15 | 419 | ||
graylensman | 4 | 138 | ||
graylensman | 2 | 93 | ||
graylensman | 8 | 196 | ||
graylensman | 3 | 122 | ||
graylensman | 3 | 116 |
183 comments found!
I can't open any .SAT files in Carrara now, and unfortunately, I don't have another application available to try. I do have a "test" account on my Mac - a bare-bones arrangement to make sure there aren't any settings in my main account that might be screwing with things. I attempted to open .SAT files in that account, and had the same results. So, it has to be Carrara.
cjd, you say the Carrara importer is corrupted. How do I fix this? Will it require a full re-install of Carrara?
Thread: Can no longer import .SAT files into Carrara 8.5 | Forum: Carrara
Thanks for the responses. I'm using Build 243 (32 bit). I'm frustrated with this, but a bit more frustrated that I've received only an automated response from DAZ, and that was five days ago.
Thread: Indoor Lighting: store-type environment - any hints? | Forum: Carrara
Thank you so much! I will give this a run this weekend, and let you know my results. Thanks again!
Thread: HDRI rendering crashes Carrara | Forum: Carrara
Thanks for the suggestion. The current map I'm using is 2000x1000 pixels, 1.4 megs in file size. Having never really done this before, I don't know if this is excessive or not. :)
Thread: vertex room - sweep path help | Forum: Carrara
Ah - no worries, Mark - it's plain to me what I'm looking at! ;)
Thanks for your help. I'll try those other tools. :)
So, are you saying I need to draw the cross section and the sweep path as one polyline, or that I can rest endpoint of my xsc on the path?
I tried the latter here, and it didn't work. The red selection along the floor is supposed to match the yellow selection, which was the sweep path.
Thread: HDRI attempt, and some weirdness in the shaders | Forum: Carrara
Thanks, Mark. I think I had all that stuff toward warp 10, but I'll go back and check. :)
Thread: The final result of the globe drama | Forum: Carrara
thanks, Miss Nancy. I'll probably revisit the rotation rate - I agree it's a touch choppy.
However, deadline looms, and I've got other portions of the project to crank out. :)
Thanks, everyone!
Quote - Well done... where is the Carrara render logo??
At the bottom of the Atlantic Ocean. I forgot to turn on render through transparency. {D
Thread: slowly spin a globe | Forum: Carrara
Thread: Now spin the globe counterclockwise! | Forum: Carrara
GAAAA!!! What an idiot!!!
I discovered that I was changing settings to my globe and camera ACROSS THE TIMELINE. For someone who always works on static images, i never even thought about this until the lightbulb went on.
Thank you all for your patience.
And naturally, as soon as I hit "post", I discovered that the cycles per second setting can accept decimal units.... d'oh!!!!
