130 threads found!
jackhalsey | 3 | 265 | ||
jackhalsey | 2 | 131 | ||
jackhalsey | 3 | 167 | ||
jackhalsey | 4 | 87 | ||
jackhalsey | 5 | 104 | ||
jackhalsey | 4 | 110 | ||
jackhalsey | 3 | 161 | ||
jackhalsey | 5 | 146 | ||
jackhalsey | 8 | 210 | ||
jackhalsey | 13 | 338 | ||
jackhalsey | 9 | 195 | ||
jackhalsey | 2 | 140 | ||
jackhalsey | 18 | 250 | ||
jackhalsey | 4 | 395 | ||
jackhalsey | 2 | 87 |
261 comments found!
Thread: Daz to poser to maya? | Forum: DAZ|Studio
Thread: Poser to Maya problem | Forum: Poser - OFFICIAL
I assume file compression which is that I used before as I create the scene and then click on save as then give it a name and it is saved as a pz3 file. Its the same procedure that used to work.
Thread: How to add runtimes to Poser 2014 | Forum: Poser - OFFICIAL
Sorry Windows 7. I did that sequence and then it said the script will kill the application and I clicked yes and Poser closed immediately. Is this correct?
Â
Thank you
Thread: Two questions | Forum: Carrara
Thread: This should be easy...but.... | Forum: Carrara
Thread: can you make a stereo camera rig in carrara | Forum: Carrara
Mark
Thank you. Can you direct me to the magazine article or be a little more specific about the multiple cameras and renders. Also what are the previz plugins for Maya that allow the simultaneous renders from two cameras?
Thank you very much.
Thread: How to better import from Poser | Forum: Vue
Okay Silverblade will work with all the information you sent me. Thank you. Okay the only question I have is how do I import the poser indoor arena scene into vue so I am not in the middle of a sunny day?
Thread: Adding the poser runtimes | Forum: Carrara
Thank you both.
Sparrownightmare thank you so much for uploading the visual..now IÂ understand.
Thank you both for the advice but how do I import into a neutral atmosphere. The arena would be an ancient fantasy arena with torches etc but how do I set it up so I am not importing into the desert?
Thank you.
Yes I would like to know how to change my atmospheres as the scene is in an arena so I am guessing it would be night..but how would I light it?
Thank you both for your help.
Thread: Import/export poser scenes | Forum: Poser - OFFICIAL
