15 threads found!
sdmakai73 | 3 | 84 | ||
sdmakai73 | 7 | 139 | ||
sdmakai73 | 8 | 144 | ||
sdmakai73 | 34 | 963 | ||
sdmakai73 | 1 | 2527 | ||
sdmakai73 | 3 | 93 | ||
sdmakai73 | 4 | 87 | ||
sdmakai73 | 2 | 82 | ||
sdmakai73 | 1 | 58 | ||
sdmakai73 | 5 | 118 | ||
sdmakai73 | 3 | 201 | ||
sdmakai73 | 8 | 361 | ||
sdmakai73 | 4 | 245 | ||
sdmakai73 | 4 | 98 | ||
sdmakai73 | 2 | 126 |
13 comments found!
Thank you very much for the quick response. Will my 3 version give my the opportunity to upgrade to 4? or will that have to be re-purchased?
Thread: Another wanting to build a new system thread | Forum: Poser - OFFICIAL
Thank you for finding those max scores. Just as I thought. There is a difference, but not really that much considering the price/performance ratio. THink I'll stick with the AMD choice, and hopefully the new FX-9590 will make it that much faster.
As for the GPU issue, I chose the higher end mainly for the CUDA support as well as open CL for other programs that I run. And when I say higher end, I not breaking the 500.00 mark.
Only reason I bring this up is I started in poser back in the day running an old Athlon XP3200 and my renders took days to render or they all had to be render in preview mode if I wanted them done in less than 8 hrs.
Now I'm running an AMD Phenom II 965 BE with 16 gbs ram and now my renders are fantastic. BUT they still take over 5 hrs with max settings.
So...I'm leaning towards the new AMD solution as that would bring my cost down, but after going over tons of benchmarks (which are mostly biased towards gamers)...would I get a noticable difference in render times with the new Intel/ AMD delema.
I know either new proc will boost my render times from what I'm seeing now, it's just hard to make a decision based on reviews and reviews which are all gamer based.
But as always thanks for the input
Thread: StudioArtVartanian Atlas render issues. | Forum: Poser - OFFICIAL
Thread: Poser->Vue7xstream-> Max issues | Forum: Vue
Solved. It's under edit objects. There is a botton for locking objects from export for those who come across the same issue.
Thread: I'm back with old problem that wont fix itself..Please help. | Forum: Poser - OFFICIAL
Well....it always seems to come down to something so simple as that. THANK YOU. I've been at this on and off for 5 months now and always saying " I'll get it this time". You people here in the community are FANTASTIC.
Thread: obj to max 6 for poser problems | Forum: Poser - OFFICIAL
Thanks for the input...I tried it to the tee, but all I got was the same flat images. even tried UVmapping and unwrap(thinking that might solve it, but for some reason M3's arms come back out as flat objects in poser. I'll keep playing around until I get this. Trial and error...that's how I learn
Thread: Honest opinions on 1st model | Forum: Poser - OFFICIAL
Thanks for your opinions...As for the density in the barrel...my first try had 16 sides and showed up REAL badly in poser even with a texture applied. I did this to "create" a more rounded look and it works well. There are alot of ways i could decrease the poly count on this model, but it was becoming a big pain for the start and did what I could just to get it finished. remember though...this was done with no prior 3d experience and was done by trial and error over a months time. I'm sure my next gun will be much better as I just bought 3ds max 5 bible.
Thread: prop imports to poser help | Forum: Poser - OFFICIAL
Thread: Reality 3 question | Forum: Poser - OFFICIAL
