5 threads found!
skcgirl | 8 | 513 | ||
skcgirl | 20 | 239 | ||
skcgirl | 2 | 31 | ||
skcgirl | 11 | 409 | ||
skcgirl | 3 | 85 |
16 comments found!
Thank you very much for the responses and suggestions. I just found out from eFrontier that it is an internal bug and Poser 7 will not render at higher DPIs than 72. Hope there is a fix soon.
Thread: GIRL 3 | Forum: Poser - OFFICIAL
The character hybrid looks simple awesome. Please add me to the download/link list. Your work is wonderful! Secret Handshake
Thread: Annoying Rainbow Flickering when rendering stairs | Forum: Poser - OFFICIAL
Hey there. Just letting you all know that I haven't forgotten to reply, I've just been working day and night trying to get my project out.
I JUST turned it in... and I ended up just doing a straight horizontal camera pan to avoid the horizontal lines from shaking. I noticed that if you don't cross the true x axis, the motions don't get blurry (I know its a low-tech solution, but it helps.) Similarly, for verical moves, you don't cross the y-axis (who says geometry doesn't help in real life?)
But since I had a sweeping move (which encompasses both vertical and horizontal), I put a semi-transparent box with some text to cover it up. It definitely masked it, so I think that the blurring ideas (2d, 3d blur, etc.) may help out... I just didn't have the extra time to experiment.
I will definitely try the ideas posted, and I thank you all!! I guess I'm not alone in this problem, and will definitely keep posting and trying to solve this issue....
Take care, SKCgirl
So far its not helping...Although I haven't had time to play with all of the settings.
I'll continue to do tests and I'll definitely post and let you all know what happened.
G'night. SKCgirl
Flicker, huh? I'll do that... since all the other keywords didn't help. After my Poser6 download finishes, I'll try the scaling thing... I'm a little afraid to see the render time, though. I read your post... hope the movie is going well... Thanks again, SKCgirl
Interesting... I will definitedly read that post... I am currently downloading Poser 6... maybe I'll see if that will help it, if not, I'll try plan B. Thanks so much for the heads up... I searched all of the forums and didn't see that post. I'll let you know if it helps. Thanks again, SKCgirl
Thanks... Oh, I meant rotating the walls, not flattening them... sorry. Yeah, the roof was a challenging fix. Took a little longer than I care to admit.
Attached Link: http://daz3d.com/shop.php?op=itemdetails&item=3176
Its actually the Fairytale Collection - Palace Entrance. I took the sides and flattened them out and made it into a mansion. I then created the "sides" the same way. The roof is from another building.Its a really nice DAZ prop... its just those stairs... ugh.
Darn. I was hoping that wouldn't be the case. Doesn't the "blur" really add onto the render time?
Does it matter whether I use Poser's render or Firefly?
So I take it this doesn't have to do with interlacing or de-interlacing? I've been trying to read up on that, and it doesn't seem like Poser has any controls like that (I believe I read that Vue does...)
Thanks again for the input, I guess now I can stop trying to "fix" it and find a way around most horizontal lines.
Take care, SKCgirl
It gives off this "vibrating" type of flicker. I've attached a photo. If you look in the stairs, you can see the curves, etc. and it seems like in each still they vary a little, so that when it plays, it vibrates.
The textures are from DAZ (as is the model).
I am importing the stills to Pinnacle Edition.
I'm not sure what other facts would help... so please let me know if there's anything else for this puzzle.
Again, I thank you... I truly appreciate you considering my problem.
Sincerely, SKCgirl
Thread: Help! Tank Style Top for Smaller Breasts Needed... Possibly Morphing? | Forum: Poser - OFFICIAL
Just letting anyone know... I found that the following tank top... We added morph targets through Tailor and it did not wrinkle to adapt with the smaller breasts. It is currently in the "freestuff" section and is called: " 072002 : Clothing for Vicky " and is made by: wusamah It was posted on July 21, 2002. (sorry, I don't know how to attach a link) This is a very well made item. Catch ya all later!! SKCgirl
Hi again... Little Dragon, I sent you my email address to send the morphs to...
Carolly... I will definitely check out Geralday's site... I had seen his "creme" before, but thought it was just a prop for a beauty scene :}
And thanks for the heads up, SWAMP... the site was working again, as well as naoki was generous enough to email me the zip files... I will definitely check out the pre-teen stuff... how sad that a realistically curvy model like the one I have is associated with a "pre-teen." Oh well.
Thanks to everyone again... you have definitely helped!!
Is that your model in the picture? Mine definitely would be a larger size than that one. But I would still appreciate seeing your morph targets if you could send them to me. I could probably learn by your example. I've emailed naoki and asked if they would send the tank to me... so, I guess we'll see. Thanks again, SKCgirl
Hi there... Thanks to you both!! Little Dragon, when I tried to download naoki's tank top, it says that the file was corrupted. I tried on two different computers. The second one on the page, the "recqueen" one downloaded fine... and although it looks like the breast size I wanted, when I tried it on my model, again it was a little big, and it wrinkled when I tried to make it smaller. And I did try using Tailor. I will keep trying... I am using aiko Model with the following morph dials: .500 Breast Gone I compare it to about a "B" cup in real life, versus the "D" plus cup that is the default. If I used your morphs, would I be able to increase the size? I'm sorry... I just don't know that much about the morphs. Thanks again!!
Thread: Color Bleed in "Bubble" while transferring to mini DV | Forum: Poser - OFFICIAL
Oh, I just realized that I didn't have the "notify" box checked, and this was the first I had known that someone responded...
Thread: Poser 7 - Resolution (300DPI and Beyond) | Forum: Poser - OFFICIAL
