99 threads found!
smalll | 3 | 341 | ||
smalll | 4 | 301 | ||
smalll | 12 | 653 | ||
smalll | 2 | 255 | ||
smalll | 3 | 364 | ||
smalll | 0 | 134 |
(none)
smalll | 4 | 241 | ||
smalll | 5 | 262 | ||
smalll | 5 | 226 | ||
smalll | 3 | 169 | ||
smalll | 3 | 304 | ||
smalll | 11 | 360 | ||
smalll | 17 | 437 | ||
smalll | 2 | 116 | ||
smalll | 6 | 300 |
162 comments found!
Thread: Pose problem | Forum: Poser 13
Thread: Can you tell me how I can fit it? | Forum: Poser 13
Thread: How can I make poser model? | Forum: Poser 13
In reference to the files linked...
There is no obj file provided which is called by the cr2, nor is there embedded geometry in the cr2 (geomCustom).
The Blend file provided promptly crashes Blender, so no way to export the obj from there in order to correct the cr2 call.
Curiously enough the rig appears to be Poser compliant in terms of classic bones internal names/body part groups conventions. Just going by the screen captures, and seeing the naming and Hierarchies.
I would try manually posing the figure and testing the results, you're attempting to apply a La Femme pose to this figure... the body part bones are different between the two. Notably the feet, this (very) partially explains the problems you're encountering there. The rig is also going to require quite a bit of joint editor work before you'll get something to even begin fine tuning. Not to mention the lack of head parts such as rigged eyes, and assuming jaw parts. You'll have to do quite a bit of work in the set up room. There's no automated solution here, at least not in my opinion, in order to get a reasonably viable Poser figure from the rig's current state. It's kind of a subjective thing, what's "good enough"...
It's a lot of work to be coming at blind. A lot. It's also quite an undertaking to explain such things on the part of whoever would undertake such a task, assuming anyone knowledgeable enough stepped forward to do so. Most of the folks you'll find hereabouts are either not knowledgeable enough about these particular aspects of Poser, or the ones who are just aren't interested or too busy to hand hold in such a fashion. It least to the extent that OP would require.
All that rambling aside, there's also the issue of OP language differences, I believe that OP speaks primarily Japanese... so there might be some confusion or translation issues in trying to explain stuff in a way that would be clear.
Just my 2 cents, for now.
Thank you very much!
You've been a great help.
primorge posted at 8:13 PM Sat, 30 March 2024 - #4483083
Here's some decent Poser rigging videos that cover the basic procedures from classic rigging to weight mapping, might help in grasping the fundamentals of process...
Classic rigging; PhilC
https://youtu.be/q8jxSOL_MAM?si=qM71xLUmPI4XZrqk
https://youtu.be/t6f6MXtKlbU?si=uzC9eYa_nOzYn27W
https://youtu.be/Nggl2JSLLtc?si=rdwwJC67lwBwfNYN
Classic Joint Parameters; PhilC
https://youtu.be/PfcPu83gZNs?si=pUFpzQi_xqNSp5D5
https://youtu.be/434MJDE4gEA?si=DPuMS1Op_ssb6xMM
Basic Rigging and Weight Mapping conventions; Diogenes/Phantom3d
https://vimeo.com/28269989
https://vimeo.com/35850999
https://vimeo.com/35978561
I'm so sorry
https://drive.google.com/file/d/1JMhhEuwtS-nQvJxCaM6CF3PIfgT02P_V/view?usp=drive_link
Thank you.
I did not make this model.
I downloaded it.
When I apply pose
You can download it
https://drive.google.com/file/d/1JMhhEuwtS-nQvJxCaM6CF3PIfgT02P_V/view?usp=sharing
How can I fix it?
Could you help me?
Thread: When I export fbx format, It has very big hip. Can you help me? | Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Thread: Could you help me? joint editor problem.... | Forum: Poser - OFFICIAL
Thread: Could you tell me how can I fix rigging problem? | Forum: Poser - OFFICIAL
