29 threads found!
stew451 | 2 | 183 | ||
stew451 | 2 | 143 | ||
stew451 | 7 | 471 | ||
stew451 | 7 | 267 | ||
stew451 | 5 | 201 | ||
stew451 | 2 | 97 | ||
stew451 | 14 | 188 | ||
stew451 | 2 | 22 | ||
stew451 | 4 | 69 | ||
stew451 | 9 | 107 | ||
stew451 | 8 | 100 | ||
stew451 | 2 | 82 | ||
stew451 | 9 | 33 | ||
stew451 | 6 | 23 | ||
stew451 | 6 | 29 |
142 comments found!
Thread: Tone Mapping | Forum: Photoshop
Thread: Any flash guru's out here? | Forum: Photoshop
Jeff, I found this on the layers magazine website (www.layersmagazine.com) hope it helps
http://www.layersmagazine.com/flash-custom-videoplayer.html
Stew
Thread: Has anyone seen this? Drastically reduce file size by adding a white layer and | Forum: Photoshop
I've used something similar for saving, but I just turn off visibility for all the layers. Didn't know about the zipping though.
Thread: After Effects Question | Forum: Photoshop
I do believe if you go to your character panel there is an option for stroke just like in Illustrator.
Thread: Deleting a Brush Set from CS2 | Forum: Photoshop
I completely forgot about holding the ctrl key to multi select. But now you know two ways to do it :)
Helgas, go to your program files folder and look for the adobe photoshop folder then go into the preset folder and open the brushes folder and delete what brush set you don't want to use any more.
C:Program FilesAdobeAdobe Photoshop CS2PresetsBrushes
The path should look like this or similar depending on what version of photshop you are running. Hope this helps.
Stew
Thread: Alternative to Photoshop? | Forum: Photoshop
Hi Keppel, I'm not 100% sure, but you could try Gimp. I know it runs under Ubuntu and you don't have to install Unbuntu to work, it runs right from the CD. It's free, but like I said I'm not 100% sure.
Thread: Multi-page printing? | Forum: Photoshop
InfoCentral i don't believe Photoshop allows for tile printing. If you have Illustrator and I think Acrobat you can do it in there. Hope this helps.
Thread: Ecosystem coverage | Forum: Vue
Thread: XP64 compatible wireless PCI card? | Forum: Vue
This one had the most reviews and a quick trip to the manufacturer page says it has drivers for WIN XP64.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833315041
There are more on this page:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=pci+wireless+card
Hope this helps.
Thread: IT'S For a Project and I need the following: | Forum: Poser - OFFICIAL
Thread: PoserPro "Can't find textures" work around | Forum: Poser - OFFICIAL
Thanks Esther. It works fine once I have the textures loaded, still have some problems with the initial texture load, but as long as I find it the first time then run the script I don't have any problems after that. Again thanks:)
And thanks SVDL and Markschum!
Thread: I NEED HELP MERGING LAYERS WITH STYLES | Forum: Photoshop
Moon,
I've had similar problems with styles and merging also. i have found that if you make a blank layer below the layer with the style effect and merge those two it for the most part helps preventing your effects from combining or changing when you merge them all into a single layer. You'll have to make a blank layer for each layer that has an effect and merge them so that it becomes a regular layer then merge all the regular layers into one. It doesn't work 100% percent of the times but it should resolve most of the problems with the effect layers. Hope this helps.
