2 threads found!
theFOG | 3 | 10 | ||
theFOG | 1 | 6 |
54 comments found!
Thread: *URGENT* Serious, proper photography help needed | Forum: Photography
A couple of ideas that may work. If your camera is able to do double exposures, take one exposed for the lights then add a second with the light off to get the case. Or try turning the lights off part way through the exposure.
Thread: Hash Animation Master forum? | Forum: Community Center
I too would like to see something on AM. It seems to be a great all around program for a bargin price. I think that if a few people started posting on it that it would soon grow. the F.O.G.
Thread: A butt ugly vampire head.... | Forum: 3D Modeling
Thread: wireframe in Bryce | Forum: Bryce
Thread: Selecting Camera | Forum: Bryce
Thread: How can I make the appearance of blood in water using Bryce 4? | Forum: Bryce
Thread: Any GIS experts out there who can answer this one??? | Forum: Bryce
Attached Link: http://www.seeing-stars.com/Landmarks/HollywoodSign.shtml
Maybe this link might help. It gives some viewing locations and has a map link.Thread: Bryce 4 blurring an image.... | Forum: Bryce
I haven't tried this my self but here goes. :-) "To find these render options click on the triangle next to the render control. To create depth of field using Photoshop. 1.Render the scene normaly using the perpective render mode. 2.Save the image in a convenient location. 3.Render the scene again, this time using distance mask render mode. 4.Save the image to the same location. 5.Open perspective render and the distance render images in Photoshop. 6.Place the distance render image into the alpha channel of the perspective image. 7.Load the alpha channel as a selection. 8.Apply gaussian blur. Objects close to you will appear sharp while object farther away will become progressively more out of focus. You can also invert the selection and apply motion blur to the image. In this case the forground would be motion blured and the back ground would be sharp as if you were taking a picture from a moving car. You could determine very specifically which objects in your scene are in focus and which are not. Select the distance render alph channel and remap the gray values in curves dialog in Photoshop, Remap black input to kighter output, and the gray value of the desired focal object to black." Taken from the Bryce5 manual but I think it will work with Bryce four also. the F.O.G.
Thread: perspective in images ? | Forum: Bryce
Just pick a point that you feel will be the focal spot of your picture (usually on the horizon) and draw you imaginary lines radiating from there. the F.O.G.
Thread: Fish Eye Render | Forum: Bryce
I think you can only go to 180 degrees on field of view. A true fish eye gets 360 degrees. You might be able to fake it by using a sphere as a mirror. the F.O.G.
Thread: Making a sunny day photo into a rainy day photo | Forum: Photoshop
Thread: Forest | Forum: Photography
I think the sky is too bright, run the picture up on your screen until the sky is off the edge and see what you think. I would crop out the sky and then see if I wanted to brighten it up.
Thread: Tips needed | Forum: Photography
If you want to brighten up the image when shooting, it's a simple solution. Use a flash, it will also help freeze the action. If after the fact that pretty well covered above. the F.O.G.
Thread: My 1st BRYCE | Forum: Bryce
