9 threads found!
vasseur7 | 8 | 483 | ||
vasseur7 | 2 | 75 | ||
vasseur7 | 6 | 344 | ||
vasseur7 | 4 | 139 | ||
vasseur7 | 2 | 148 | ||
vasseur7 | 8 | 390 | ||
vasseur7 | 1 | 88 | ||
vasseur7 | 6 | 387 | ||
vasseur7 | 0 | 55 |
(none)
19 comments found!
Thread: Poser 5 - Bonus Content | Forum: Poser - OFFICIAL
Mine is the Mac version and it is in the first file. However, I don't have .exe files. I have a disk image that mounts like a CD when you click it and when you do the Bonus folder shows up right next to the installer. Again, Mac version. Good luck.
If you downloaded the CP deal it was in the file that includes the Poser 5 Installer. Look for a folder called "Bonus Content".
Thread: Poser 5 - Bonus Content Don & Judy | Forum: Poser - OFFICIAL
These are part of the CP deal. They are on the Poser 5 install CD file that is the first downloaded file in the Bonus Content folder. They are not part of the "Poser 5 Hero Content" download.
Thread: Bryce, Vue, or LightWave -- Your input much appreciated! | Forum: Poser - OFFICIAL
I agree with the Carrara recommendations above. If you do a lot of landscape Carrara can hang with Vue 5 infinate and it has better rendering options that Vue won't support until version 6. Go to the galleries in this forum and see the Carrara landscape section and compare it to the best Vue stuff. You tell me which is better? They are both excellent. Carrara however has more sophistocated modeling capabilities than Vue. If ytou can afford both get them. If you only have the $ for one then get Carrara 5 PRO.
Thread: Presets - Where can I find collections? | Forum: Carrara
On a on a related note. Are older shader packs for older versions of carrara compatible with version 5. I know I can import some of them, but will they support the same characteristics in 5 as they did in the version they were designed for, or will I lose features and functionality.
Thread: Landscape generation in Carrara 5.1 vs. Vue Esprit 5 | Forum: Vue
Thread: Render Nodes and Extensions | Forum: Carrara
Great! How about Shaders created from those extensions? Does it just pull the shader data from the main computer? I do not really see a way of installing the shaders if it was necessary. Thanks again for your help. =-) CV
Thread: Landscape generation in Carrara 5.1 vs. Vue Esprit 5 | Forum: Carrara
Wow!! Mark Bremmer responds. I guess that is as qualified an answer as I can expect to get. Thanks for the feedback I really appreciate it. =-)
