Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 9:06 pm)
This happens when pivot points are moved. Resetting the pivot on all your objects before you export the model can fix the problem, but here's a more reliable way (in MAX 3, but the procedure should be similar): Select one of your objects that is currently an editable mesh. Then click the "Attach" button, and select all the other objects (one at a time) you wish to export as a single model. If these objects have different materials assigned (materials should be assigned first, BTW) it will prompt you as to how you want to handle it. Select "Match Material IDs to Material" and your individual materials will remain intact. Unclick the Attach button and export the new, single mesh. This is how I export every MAX model, and I have yet to have a problem with it. Hope this helps! Nice Helmet BTW.. -=JFStan=-
Attached Link: http://www.habware.at/duck4.htm
Free obj exporter/importer for Max 4. Change the 4 to a 3 in the address for free Max 3 plugins.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
