Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
My python page
My ShareCG freebies
#1. You can use Lock Actor as described by Ockham, but I offten find that I have to lock and then unlock several parts to make adjustments, then lock them again. In these circumstances I parent all the parts of the set to Minimal Figure (one that has no or very little geometry). Once all the parts are parented locking this Minimal Figure (Figure > Lock Figure) will also lock all the props attached to it. I can also move, scale, rotate, or delete, all the props as a unit by performing these actions on the the figures body actor. You can make a Minimal Figure by using the Hierachie Editor to convert a Poser SQUARE prop into a figure, then load the new figure, hide the 'square_1:1' actor and resave the figure to a pallet. A variation on this idea is to use a text editor to completly remove the square_1 actor from the file leaving only the BODY actor.
Hello All. Any help would be appreciated.
I created a set for my characters to pose in using BeyondBent's SFCS. This uses modular props to create floors, walls, and ceilings. My question is this: after I have created a setting, how can I lock the pieces into place so that I do not accidently select and move them?
If I use ctrl-H to Hide and object, how can I make it visible again? If I use the hierarcy editor to hide it, I just click the eyeball icon to bring it back. But this will not make something visible that was hidden with ctrl-H.
In Poser 4, when I try the Help feature, I get nothing. Are there online help files in Poser 4 and how can I see them?
DrOsborn
