Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 25 12:38 pm)
You should reinstall Poser 4 direct from the CD and then install Poser Pro over it without installing any of the MC/CL patches.
I kept my patched version of P4 in my Metacreations directory and then installed a 2nd copy in a Curious Labs directory and the installed the ProPack over that. I will generally work in Poser Pro, but I'll always have 4.03 available for testing purposes.
Attached Link: http://www.donnyd.com
Having 2 versions installed at the same time in windows won't cause any problems with the registry? I mean, does it mess wiht your preferences? Extremely curious since I just ordered propack DonnyWell, your poser preferences are installed within your poser directory, so as long as you keep your two versions in separate directories, they will each read their separate preferences. As far as file type concerns, I haven't tried double clicking a .pz3 file yet so I don't know if the pz3 will open in P4 or PP. I can always change this if I need to, but I rarely open a pz3 from windows anyway.
BTW, I can't run both P4 and PP at the same time. If PP is running and I try to launch P4, it merely makes my PP window active.
I reinstalled Poser, the 4.03 update & Pro Pack! Still I can't change any textures!!!!! Aaargh, good grief! Rats! I feel like a blockhead! Does anyone have any ideas what's up? I'm running WinME with a Geforce2 & 160meg Ram! Idon't know if my hardware's causing any bugs to become prevalant or if it's just Poser or what! H E L P ! ! !
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
JKeller - That's what I did first & had the same problem... After checking in my manual & the Curious Labs Support area, it said that the ProPack wouldn't function with a non-updated version of Poser (but it did function - just not properly). Then I reinstalled EVERYTHING! And was left with the same problem... sigh... I'm going to give up until the weekend. Thanks!
The GR00VY GH0ULIE!
