Tue, Feb 18, 3:45 AM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: P6 Question
Faery_Light ( ) posted Sat, 13 May 2006 at 12:42 AM · edited Tue, 18 February 2025 at 3:42 AM
Online Now!
Hi;
I'm hoping to pinch pennies until I get enough for P6.
I'm wondering about the runtime folders.
After losing loads of Poser goodies and image files, textures and photos to a disk failure or virus, I want to back everything up to DVD.
Now if I create a runtime folder with all my poser goodies in it, will it run right from the DVD in P6?
Or will it have to be put in the P6 directory?
It sure would save frustration and disk space if it can run right off the DVD.
Thanks for any information.
Blu
Let me introduce you to my multiple personalities. :)
     BluEcho...Faery_Light...Faery_Souls.
Miss Nancy ( ) posted Sat, 13 May 2006 at 2:31 PM
I haven't tried that, as DVDs only hold 4.7 GB (or maybe it's 9.4), but it definitely works with external firewire drives. My guess is that it won't work with DVDs, as they're read-only, but I could be wrong.
PoseWorks ( ) posted Sat, 13 May 2006 at 2:39 PM
You will run into issues with loading content off of DVDs, because paths are stored from the drive letter (ie, G:/Victoria3/Runtime/Geometries/DAZ/MilWom/blMilWom3.obj)
Unless the DVD with those necessary files on it was always in the drive, you would be unable to open scenes using content from any Runtimes off of the DVD. Poser may also throw errors when starting up if it can't find your DVD Runtime.
I would recommend using an external/portable hard drive rather than DVDs, and keeping the same drive letter mapped to the external drive.
Faery_Light ( ) posted Sat, 13 May 2006 at 4:48 PM
Online Now!
Hmm, well guess i'll just use them as back-up and re-load to Poser as needed.
It was my external hard drive I lost.
I had forgotten about the path thing. Don't know where my mind is lately. Still hurting from that last loss I guess.
Had about 60gb of stuff there not including programs on it.
The prgrams I had on CDs and that's no prob. But I hadn't backed up eveything yet.
The actual loss was just to my texture librarie I had built up, photos and psd files.
I lost three character sets that were alomost ready for the MP. Now I have to do it all again.
This time around I'll back up every night.
Thanks for the info.
Blu
canwetalk ( ) posted Sat, 10 June 2006 at 8:58 PM
I have use a DVD for my Runtime folders before. Did not have any problems using it other than it was a little slow.
How I did it was after I made my DVD which had  several runtime folders...Animals-People-Props and so on...
Anyway after I made the DVD  I copied all the Geometries and Textures from the DVD into Poser.
It worked fine and I didn't have a lot of things inside of Poser. However as I said it did run a little slow in that way, but I also have an older slower DVD drive and not a lot of ram on my system.
Hope this helps
