Thu, Feb 27, 4:18 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 27 3:55 am)
Subject: Add Material and assign Material?
3dz ( ) posted Thu, 05 July 2007 at 10:22 AM · edited Thu, 27 February 2025 at 4:00 AM
What is the differrance between Add Material and Assign Material on the group editor? :huh:
Tyger_purr ( ) posted Thu, 05 July 2007 at 10:38 AM
Assign material will assign the currently selected polygons to a material group
Add Material will add the polygons in a material group to the selected group
My Homepage - Free stuff and Galleries
3dz ( ) posted Thu, 05 July 2007 at 5:13 PM
Let me see if understand this correctly.  If I have two polygons from one group, and two polygons from another group.  I can assign them the same material, even though they are from two different groups? If they are selected that is?
LostinSpaceman ( ) posted Thu, 05 July 2007 at 7:22 PM
Add Material will pull down a dropdown list of existing materials which are already assigned to polygons and add all of their polygons to the group you're working on. Assign Material is where you assign a new material name or existing material name to the grouping that you are working on, it doesn't change your group polycount at all.
3dz ( ) posted Fri, 06 July 2007 at 3:24 PM
I need to think this over a little bit.
LostinSpaceman ( ) posted Fri, 06 July 2007 at 3:37 PM · edited Fri, 06 July 2007 at 3:40 PM
No, You can assign multiple groups the same material but you can't assign materials to 2 polygons of one group and two polygons of another group without creating a whole new group with those four polygons. The reason is you can't select polygons from another group without inadvertantly adding those two polygons to the group you're working on.
The grouping tool will only work on one group at a time. When you select polygons from another group, what you're doing is adding them to the current group and removing them from their previous group. This isn't something you want to do with Poseable figures.
