Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 11:01 am)
The most obvious thing you need to do is turn on the "Make polygon normals consistant" option when importing into Poser.
If that doesn't cure the "missing" polygons, then you'll need to use a modelling app to correct them (or as PhilC mentioned earlier as trip through UVMapper will often fix problems).
It's likely one of your C4D export settings is doing this... I'm not a C4D user so I couldn't help you with specifis. When I use 3DStudioMax, there's a number of export settings that could change my geometry in undesireable ways, some of them looking a lot like what you're getting.
Your best bet may be asking someone in Cinema4D forum what are best Cinema export settings. ... or maybe one of C4D users will stumble upon this thread... (but there's no C4D in the title, so they may not...)
Looks like on export from Cinema, the mesh got triangulated, instead of being left as quads. I'm not aware of anything being able to fix that, outside of the originating application (C4D)
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Somwhow I've got the idea it's a Poser 7 prob. In P 6 it was never a prob to export a body part of a figure, modify it in a 3D app and use it as a morph target. Now I have to use UV Mapper to re-arrange the vertices.
Ulli
This was the sort of thing that was a recent problem in a few freebie models
Poser wasnt reading the continuation
a large number of quads suddenly became tris .
f 26349/10767/12873 26373/10766/12872 26374/10768/12874
26350/10769/12875
f 26350/10769/12875 26374/10768/12874 26375/10770/12876
26351/10771/12877
f 26351/10771/12877 26375/10770/12876 26376/10772/12878
26352/10773/12879
easy enough to fix once someone figured it out.
I undertook the challenge to convert this obj model into Poser for a friend. In cinema4d the model geometry looks correct: all the polys are quads. When I import it into Poser everything has been triangulated and half of the polys have diappeared. Check out the image I included. Does anyone have an idea of what is going on and how to correct it?
I would appreciate any assistance you good folks can offer.
