Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
SHIFT-CTRL-f
You can see the list under Edit/Restore.
Keep in mind that this shortcut zeroes everything--pose + morphs. If you want to keep the morphs, use Edit/Memorize/Figure.
There isn't an inherent shortcut for turning off IK, though there are some pose files around for that purpose, but finding them and waiting for the pose to be applied takes about as much time as manually turning them off (usually IK is only on legs). I think that resaving a figure to the library, after turning off IK, keeps the IK off for the saved figure.
My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
Whilst Ctrl+Shift+F is very useful, and may be sufficient for your requirements depending on what those are, it is not strictly speaking the same a zeroing the figure.
Ctrl+Shift+F restores the figure to its last memorized state, if you did not use any of the Memorize functions, this will probably be default pose, the same pose the figure had when first loaded. But note that for many figures not all the joint rotations are zero in the default pose.
i'm doing a lot of zeroing lately.
oh, and a hotkey to turn off/on all the IKeys?
left leg off, right leg off, left arm off, right arm off.
