Fri, Nov 22, 10:16 AM CST
Renderosity Forums / DAZ|Studio
Welcome to the DAZ|Studio Forum
Forum Moderators: wheatpenny Forum Coordinators: Guardian_Angel_671, Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 21 11:14 pm)
Subject: Reality Render thread. A new beginning.
Pret-a-3D ( ) posted Fri, 10 May 2013 at 12:49 AM
Quote - You mean it wont be like using R2? I could of swore that Paolo said it would be not much different if one was use to R2. Part of the reason for the new rig was to be R3 ready now you have me a bit concerned cause I know how good you are with 2...
It is very similar, it's an extension of it. You can see it in action if you watch any of  my Reality 3 videos on YouTube:
http://www.youtube.com/user/PretA3D
The window partitions the action in the usual tabs: Materials, Lights, Camera etc. The main change is that the Output tab, which was always too crowded has been renamed Render and it's neatly organized in smaller groups. Nothing dramatic there.
The main change in the material editor is that, where in Reality 2 you have a fixed combination of color and an image map, now you can use any of the texture types available from Lux. For example, you can have a mix texture that mixes two textures together. Those two texures can be an image map and a swirly pattern made with the "Distorted noise" texture. Where before we had only the material preview now there are also preview for the procedural textures. For example, you can add a Wood texture (see video) and you see the wood pattern change as you edit the parameters. It's pretty cool.
Unlike other systems, Reality 3 achieves all this power without using nodes. It uses a more familiar system of "drilling down" the levels and navigating back, similarly to a web browser.
The familiar material types are there too, with the addition of Skin (with SSS) and Cloth.
There is the addition of the Volumes, which can be used for really neat effects. You can see how simple they are to use in the video aboiud creating a beam of light.
The big difference is also that Reality is a separate program that runs in parallel with the hosting application, Poser or Studio. This means that  Reality does not block you from using Poser. You can keep the Reality window open while you go back to Poser and adjust the scene. The same will be for Studio. I think that that is actually a great improvement.
With this system Reality retains the whole set of settings for the rendering in one single window, which is convenient to control all the aspect of rendering, material editing etc.
Hope this helps.
Paolo
https://www.preta3d.com
FB: https://www.facebook.com/RealityPlugIn
Tw: @preta3d
G+: https://plus.google.com/106625816153304163119
The Reality Gallery: https://reality-plug-in.deviantart.com
bobvan ( ) posted Fri, 10 May 2013 at 12:55 AM
I guess I will see once I get it it wont be much since for us it will only be an upgrade cost...
bobvan ( ) posted Fri, 10 May 2013 at 7:09 AM · edited Fri, 10 May 2013 at 7:09 AM
bobvan ( ) posted Fri, 10 May 2013 at 7:10 AM · edited Fri, 10 May 2013 at 7:11 AM
john3d ( ) posted Fri, 10 May 2013 at 7:40 AM
Paolo wrote - Where before we had only the material preview now there are also preview for the procedural textures. For example, you can add a Wood texture (see video) and you see the wood pattern change as you edit the parameters. It's pretty cool.
I like the sound of that Paolo, I can see myself making floors and wooden furiniture etc - now I'm looking forward to Reallity 3 for DS
Pret-a-3D ( ) posted Fri, 10 May 2013 at 9:11 AM
Yes, the power of procedural textures is quite nice to have. Glad that you like it John.
Cheers.
Paolo
Tw: @preta3d
bobvan ( ) posted Sat, 11 May 2013 at 12:10 AM
Got the beast today not installed eveything yet...
john3d ( ) posted Sat, 11 May 2013 at 12:56 AM · edited Sat, 11 May 2013 at 12:57 AM
I like your test animation Superboomturbo
bobvan ( ) posted Sat, 11 May 2013 at 2:19 AM · edited Sat, 11 May 2013 at 2:20 AM
Help! Reality often just shuts down with win 8 any way around that?
inquire ( ) posted Sat, 11 May 2013 at 2:50 AM
Quote - Nice cat we lost both of ours in the aftermath of the fire thanks to some never to be named again or suffeciantly damned inlaws
Got all the parts in for my cousins and my machines so I get to start building here as soon as we get the apartment furnished
I'm very sorry. I know how painful it is to lose a pet. You have my regrets.
bobvan ( ) posted Sat, 11 May 2013 at 3:22 AM
Reality wont run properly on my new system gotta get win 7 on it...
Doctorjellybean ( ) posted Sat, 11 May 2013 at 3:22 AM
Quote - Help! Reality often just shuts down with win 8 any way around that?
No.
Ok, I guess you want more than that. There is something which prevents Reality from loading 90% of the time on a Windows 8 x64 system. It will eventually load, but my advice is to use Windows 7 x64. There is a planned update for Windows 8 later this year, might be best to hold off until then. I am.
My DA Gallery
bobvan ( ) posted Sat, 11 May 2013 at 3:25 AM
Quote - > Quote - Help! Reality often just shuts down with win 8 any way around that?
No.
Win 8 came with my new system but there is a right to roll back to 7. That's prolly what I will wind up doing also the lux files that I transferred from the old to the new machine wont save properly even though I have the same version path and collected textures on both its infuriating!
Doctorjellybean ( ) posted Sat, 11 May 2013 at 3:35 AM · edited Sat, 11 May 2013 at 3:36 AM
Quote - Win 8 came with my new system but there is a right to roll back to 7. That's prolly what I will wind up doing also the lux files that I transferred from the old to the new machine wont save properly even though I have the same version path and collected textures on both its infuriating!
I would do that.
Re Lux, if you have the exact same path on the new machine as specified in the *.lxs file, then it should save properly. Reality currently has an issue where it hardcodes the path in the *.lxs file (approx line number 14):
"string filename" ["F:/Renders/"Room Of Mirrors"]
I edit it so it reads
"string filename" ["Room Of Mirrors"]
before transferring anything to another machine.
My DA Gallery
bobvan ( ) posted Sat, 11 May 2013 at 3:39 AM
I am so doing it I cant even run Reality on this beast. Worse thing is they were selling it to me with 7 but my guy at work told me to go with 8. But the guy from the store showed me the M$ link where one is allowed to roll back to 7...
bobvan ( ) posted Sat, 11 May 2013 at 4:01 AM
Its seems kind of silly ot me that anyone purchasing a newer system would unable to use Reality. Anyhoo I would I edit this file to work on the new machine?
Doctorjellybean ( ) posted Sat, 11 May 2013 at 4:16 AM
Quote - Its seems kind of silly ot me that anyone purchasing a newer system would unable to use Reality. Anyhoo I would I edit this file to work on the new machine?
They are still able to use it, it would just be a hit & miss affair. Maybe this will be easier with R3.
Yes, you edit that file and change line 14 so that it looks like this:
My DA Gallery
bobvan ( ) posted Sat, 11 May 2013 at 4:24 AM · edited Sat, 11 May 2013 at 4:35 AM
Thanks. For certain scenes I was barely able to open Reality im not putting up with it 7 will be on it by next week...Thanks Anton that works like a charm! Hope all is well with you.
bobvan ( ) posted Sat, 11 May 2013 at 4:48 AM
This way I can remain operational using the new hog to do the rendering until I git win 7 on this puppy...
bobvan ( ) posted Sat, 11 May 2013 at 5:33 AM
Wow man this thing is soo quiet and runs cool
UHF ( ) posted Sat, 11 May 2013 at 9:33 AM
Uninstall Windows 8?   :-)
bobvan ( ) posted Sat, 11 May 2013 at 9:35 AM
Its a done deal!
ESarge ( ) posted Sat, 11 May 2013 at 9:58 AM
Ihave run win8 and reality 2.5 and Reality 3 for some time now with no problems. I have never had Reality shut down on me, or any other problems.
Thanks for the tip on editing the .lxs file Doc.
bobvan ( ) posted Sat, 11 May 2013 at 10:00 AM
Quote - Ihave run win8 and reality 2.5 and Reality 3 for some time now with no problems. I have never had Reality shut down on me, or any other problems.
I wonder whay that is.... Maybe it works better with an nvidia card?
Pret-a-3D ( ) posted Sat, 11 May 2013 at 10:09 AM
Quote - I wonder whay that is.... Maybe it works better with an nvidia card?
There is not interaction with the video card and Reality whatsoever.
It's just Microsoft :)
Paolo
Tw: @preta3d
bobvan ( ) posted Sat, 11 May 2013 at 10:26 AM · edited Sat, 11 May 2013 at 10:29 AM
Quote - > Quote - I wonder whay that is.... Maybe it works better with an nvidia card?
Thats why it  works for some not for others? As I said M$ allows roll back to win 7...
Pret-a-3D ( ) posted Sat, 11 May 2013 at 10:34 AM
If you look at past releases of Windows, each and every one has broken something. MS is simply unable to deliver a software that is backward compatible.
Paolo
Tw: @preta3d
ESarge ( ) posted Sat, 11 May 2013 at 10:40 AM
Let me correct my earlier post. I just started another reality render and had to click the Reality icon 3 times before it started up. This happens very seldom but this might be what you guys are talking about. It is a minor irritation, because when Reality starts it works fine. This problem only happens in DS not poser. Sorry I had forgotten about this when I first posted.😊
bobvan ( ) posted Sat, 11 May 2013 at 10:46 AM
This happens everytime I try opening up Reality i JUST got this system it happened from the get go..
bobvan ( ) posted Sat, 11 May 2013 at 11:02 AM
You guys are right if I keep hitting it it eventually comes up thanks for that also Reality reads that it finds Lux 0.9 even though I have 1.2.1 installed at least I can manage for now....
bobvan ( ) posted Sat, 11 May 2013 at 11:18 AM
Being able to switch back and forth between both machines on my 27" monitor is pretty cool
bobvan ( ) posted Sat, 11 May 2013 at 5:48 PM
Now that I know Reality will work I may ride it out since R3 is not too far away anyhoo the beast..
bobvan ( ) posted Sat, 11 May 2013 at 7:11 PM
Attached Link: http://bobvan.deviantart.com/art/Island-33-371090377?q=gallery%3Abobvan&qo=2
1st Hybrid render on both machines
bobvan ( ) posted Sun, 12 May 2013 at 12:59 AM
Not sure how am I doing it but I am  getting Reality to open alot more now...
john3d ( ) posted Sun, 12 May 2013 at 3:42 AM
Has anyone been in contact with Callad ? Not seen her around lately.
I just checked my Join Date here, I feel old :)
Doctorjellybean ( ) posted Sun, 12 May 2013 at 3:49 AM
Hah John, you are a spring chicken! Mine is 5 years older :)
Callad is ok, I think. I heard from her last week.
My DA Gallery
Doctorjellybean ( ) posted Sun, 12 May 2013 at 7:58 AM · edited Sun, 12 May 2013 at 7:59 AM
Anybody got this?
http://www.renderosity.com/mod/bcs/sav-alpha-scalp/99012/
It doesn't seem to play nice in Reality.
My DA Gallery
Reggie68 ( ) posted Sun, 12 May 2013 at 9:11 AM · edited Sun, 12 May 2013 at 9:24 AM
A Question for Paolo...
Image and video hosting by TinyPic
(Fixed link)
Doctorjellybean ( ) posted Sun, 12 May 2013 at 9:18 AM
I think the render link is wonky.
My DA Gallery
Pret-a-3D ( ) posted Sun, 12 May 2013 at 9:55 AM
UHF ( ) posted Sun, 12 May 2013 at 11:07 AM
Quote - Anybody got this?
I was curious about that myself.  For 3.50 I bet its OK.    Likely however, it is using some sort of magic shader and those never play well with Reality.
bobvan ( ) posted Sun, 12 May 2013 at 12:53 PM · edited Sun, 12 May 2013 at 12:54 PM
Attached Link: http://bobvan.deviantart.com/art/Island-36-371243340
Thanks guys for letting me know Reality will open in 8. Got some rendering done marked improved render times. I have to call where I got my system since my front USB 3 ports are not active I will plead with them to let me get 7 on it.
bobvan ( ) posted Sun, 12 May 2013 at 12:55 PM
bobvan ( ) posted Sun, 12 May 2013 at 2:19 PM
Yaaaayy They are going to put 7 back on for me
bobvan ( ) posted Sun, 12 May 2013 at 10:21 PM
Doctorjellybean ( ) posted Mon, 13 May 2013 at 3:11 AM
It has been awhile since I rendered something. This took just over 200 hours, due to the infinite mirror reflections.
Treasure
My DA Gallery
bobvan ( ) posted Mon, 13 May 2013 at 3:14 AM
No kidding thats nuts (In a good way:)
Doctorjellybean ( ) posted Mon, 13 May 2013 at 3:54 AM
It does. One needs to adjust the Geometry settings on the Modifiers section, as it uses Displacement maps. Set Subdivision to e.g. 2 and check Use Micro Facets.
Quote - > Quote - Anybody got this?
My DA Gallery
bobvan ( ) posted Mon, 13 May 2013 at 3:56 AM
Anton I am curious did you ever try to troubleshoot install Reality in 8 ? I got office starter to work using that method when it would not install previously.
Doctorjellybean ( ) posted Mon, 13 May 2013 at 4:11 AM
I had the same problem where it would take a couple of goes before it would load. Sometimes I had to shut DS down, restart and reload the scene before Reality would load. Way too much hassle, especially after x number of times.
I'll try it again once the Windows 8 update has been released, and Reality3 for DS is available.
My DA Gallery
