Thu, Nov 14, 4:03 PM CST
Renderosity Forums / DAZ|Studio
Welcome to the DAZ|Studio Forum
Forum Moderators: wheatpenny Forum Coordinators: Guardian_Angel_671, Daddyo3d
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 14 3:44 pm)
Subject: Rigging for V4 in DS4
madmitch ( ) posted Mon, 23 July 2012 at 3:57 AM · edited Fri, 09 August 2024 at 6:12 PM
Is it possible, either directly or indirectly, to use the transfer utility in DS4 to rig clothing to fit V4? When I have tried it , with V4 in the scene, V4 is not offered as an option for the source rigging.
I can do it in Poser, then use the result in DS4, but it would be better if it all could be done in DS4
RHaseltine ( ) posted Mon, 23 July 2012 at 9:31 AM
Online Now!
If you don't want to leave DS4 one option would be to convert V4 to a TriAx weight-mapped figure (Edit>Figure>Rigging>Convert Figure to Weight Mapping), at which point the Transfer utility would work as with Genesis. The alternative, and the way most people do it, is to select V4, then open the Figure set-up pane; right-click on the pane's tab, or click the menu button in the top corner, to get the option menu and select Copy from selected Figure; right-click in the Geometry List area and import your clothing OBJ, which must already be grouped; drag the OBJ from the Geometry List into the Hierarchy - it should replace the V4 geometry on bones that match; delete unneeded bones by right-clicking on them - remove the geometry from bones you want for stability but which don't have any geometry in your clothing (for example, if your sleeves end at the forearms you will want to keep the hand bones, but with nothing for geometry); make sure Modify Selected is checked at bottom-left of the pane; click the Create button. Then you will have to use the Joint Editor tool to adjust the falloff zones.
madmitch ( ) posted Mon, 23 July 2012 at 2:45 PM
Many thanks Richard
