Mon, Jan 6, 9:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 06 7:01 am)
Subject: POSER CANNOT FIND AN OPEN PORT FOR LIABRARY COMMUNICATION
atpo ( ) posted Mon, 06 January 2014 at 7:04 PM · edited Mon, 06 January 2025 at 9:21 PM
poser cannot find an open port for liabrary communication.please sure no firewall or anti-virus software preventing.
here I close win firewall and win defender and anti-virus software.
but when start poser ,then poser is closing at once.
how to deal with?
WandW ( ) posted Mon, 06 January 2014 at 9:15 PM · edited Mon, 06 January 2014 at 9:15 PM
Did Windows Update add Internet Explorer 11?  If so, you need to get the latest Service release for Poser 9 or higher.
http://poser.smithmicro.com/updates.html
If you are using Poser 8 or PP2010, you need to uninstall IE 11...
PS Lovely fish!  😄
atpo ( ) posted Tue, 07 January 2014 at 12:55 AM
thanks.
install content to "poser directory" ,then firewall prevent.while install to 'share',is very large.
so install to 'poser directory',how to modify win firewall and anti-virus software so that let liabraries have an open port.
WandW ( ) posted Tue, 07 January 2014 at 6:42 AM · edited Tue, 07 January 2014 at 6:45 AM
Ol K, By Firewall you mean Windows User Account Control, presuming you have Poser installed somewhere in the c:Program Files folder.  This is why the content needs to be installed outside of C:|Program Files on Windows Vista or higher; It is a security feature and only Poser can write to that directory.  You don't have to install content to Shared Documents if you have space somewhere else, such as on another partition; just specify where you want it installed if you are installing Poser.  If you are installing new content create a directory, (mine is called 'Poser Library') unzip the content there and add it to the library as an external runtime.
User Acount Control can be disabled, but it is not recommended because of security issues, so I would find a different location for your content, but if there is no other way; do this at your own risk...
http://windows.microsoft.com/en-us/windows/turn-user-account-control-on-off#1TC
EDIT; I should add that a sneaky way to get around this is simply to install Poser outside of c:program files, such as in C:Poser.
To allow Poser access to the internet, set your firewall to allow access to Poser.exe and FFRender.exe (or PoserPro.exe, FFRender.exe and lsmgui.exe if you are using Poser Pro) Here's how to do it for the Windows 7 firewall...
http://windows.microsoft.com/en-us/windows/communicate-through-windows-firewall#1TC=windows-7
atpo ( ) posted Wed, 08 January 2014 at 12:17 AM
thanks
I install poser pro 2012
I modify win firewall by that way.
I install content to c:,and c is out
now I try creat a port for content.
WandW ( ) posted Wed, 08 January 2014 at 6:46 AM · edited Wed, 08 January 2014 at 6:47 AM
SO C: drive is full?  If ypou weren't able to to complete the content installation the easiest to handle it is to delete the content directory (presuming it contans only the included content, and not any of yours)  and reinstall Poser , pointing it to install the content on another drive; either to a D: or E: drive, or to a mapped network drive.
If you have a network drive, you should be able to map  the network directory and install the content there...
http://windows.microsoft.com/en-us/windows/create-shortcut-map-network-drive#1TC=windows-7
Since you are using Poser Pro 2010, you will certainly need to install the update before running it.  If it still won't start, you may also need to manually switch the external library on be editing Poser.ini, which can be found in your user data under Application DataPoser Pro9.0, and changing LIBRARY_IS_AIR from 0 to 1...
