Sat, Jan 18, 5:14 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 10:25 am)
Subject: OBJ viewers?
DarkElegance ( ) posted Thu, 16 January 2014 at 8:54 AM ยท edited Sat, 18 January 2025 at 5:10 PM
I finally got an ancient HD of mine reading...and happily found a folder with...unfortunatly hundreds of OBJs. Random stuff that had been downloaded over the years. The names on the files do not really tell me much.(I think there is nearly a gazillion "arches")
ย
is there a program out there that will let me see the OBJ without me having to load each and every single one in poser? Something that will allow me to see a thumbnail like when I open a folder that has jpgs and it lets me see them?
ย
https://www.darkelegance.co.uk/
Commission Closed till 2025
willyb53 ( ) posted Thu, 16 January 2014 at 9:03 AM
I use http://www.sharecg.com/v/47407/related/10/Software-and-Tools/PropViewer-3.2?interstitial_displayed=Yes
ย
Bill
People that know everything by definition can not learn anything
DarkElegance ( ) posted Thu, 16 January 2014 at 9:13 AM
Quote - I use http://www.sharecg.com/v/47407/related/10/Software-and-Tools/PropViewer-3.2?interstitial_displayed=Yes
ย
Bill
I just downloaded it and it doesnt seem to work. When I try to open a obj the teapot just goes nuts spinning. >.<
geep ( ) posted Thu, 16 January 2014 at 9:24 AM ยท edited Thu, 16 January 2014 at 9:25 AM
Attached Link: Get FREE P3dO mExplorer HERE
*(click the image to view full size)*
I use P3dO Explorer from Senosoft.
It works great.
You can view .obj files directly and rotate the view.
And ... It's FREE !!! ๐Ÿ˜„
cheers,
dr (bob) geep
cheers,
dr geep ... :o]
edited 10/5/2019
DarkElegance ( ) posted Thu, 16 January 2014 at 3:26 PM
Quote - (click the image to view full size)
It works great.
cheers,
dr (bob) geep
YES! that is perfect! exactly what I was needing!!!thank you!!
aldebaran40 ( ) posted Thu, 16 January 2014 at 3:59 PM
It works great.
cheers,
dr (bob) geep
ย
Thank you for this
EnglishBob ( ) posted Fri, 17 January 2014 at 4:00 AM
I use Kawecki's Prop Viewer (as linked by willyb53) all the time for viewing OBJ, 3DS and prop files with internal geometry. It's fast and has other useful features too.
However if it can't understand your file, you get the Utah Teapot instead. :) Two main reasons for this are:
  1. Your OBJ was 'squished' for use as a morph target, i.e. it has no facet information; no polygons. Your only option in this case is to use a viewer or modeller that will display vertex-only information.
  2. (Not relevant to you, since you're viewing OBJs) You gave it a prop file which calls an external geometry file. In that case you need to find where the geometry is and view that instead.
Jules53757 ( ) posted Fri, 17 January 2014 at 4:22 AM
And P3dO has an additional advantage, you can use it as Poser library and load items directly from P3dO
Ulli
kawecki ( ) posted Sat, 18 January 2014 at 4:57 AM
PropViewer can handle and process big meshes as 10 million polygons. I don't tried bigger.
In general survives to corrupt meshes without crashing and tries to repair it whenever is possible.
You can load Poser meshes with internal geometry (pp2, cr2, hr2) and dynamic hair and can load 3ds, obj, dxf, ply, off and stl formats.
Can export as obj, pp2 and LuxRender (lxo+lxm+lxs)
You can perform several operations with the mesh: Reverse normals, Mirror,X,Y,Z; Weld, Convert to quads, Convert to triangles, Split, Smooth (taubin), Subdivision (Middle-point), Fix normals, Remove duplicated faces, Remove non two-manifold faces
Just finished something like drape or convert to a regular mesh (don't know can call it)
Not all these features are present in the uploaded version.
ย
Working in other subdivision schemes, decimation and Poisson reconstruct (turn point cloud into a mesh)
Stupidity also evolves!
EnglishBob ( ) posted Sat, 18 January 2014 at 11:54 AM
I like the sound of those additional features - looking forward to their release!
I've said it before: I'd gladly pay for a PropViewer Pro, especially if it has cool new features added from time to time. ย
jonnybode ( ) posted Sat, 18 January 2014 at 12:29 PM
quote / I'd gladly pay for a PropViewer Pro / end quote
I second that, a most useful program this one!
