Bryce F.A.Q (Last Updated: 2025 Feb 17 1:22 pm)
Just adding my 2 cents, I would repeat what cowtoast said. In all of my many posted images, where I use the basic terrain models that run flat to the surrounding area, I always lift the red in the terrain editor, most often having set the resolution to something over 512 in that little grid area. This is also necessary if you use the terrains for making objects you can use. Just draw out your shape, raise the "red" and you'll have the object without the square base around it. Walt "Mike"
Well, while trying to put some islands in some water, I found out that it was messed up, as you can see in the image, the water has a really bad transparency (I even played w/ the material and changed the trans, but that didnt work at all) Does anyone know what is going on? Thanks
