I'm also kinda curious how you got anything with no lights, no sun and no ambience, blurry reflections won't have anything to do with it.
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=251269&Start=1&Artist=AgentSmith&ByArtist=Yes
I've done pics with no lights, but I had to use the "True Ambience" render setting, and my materials needed an ambience setting of around 15. Lesse if Ornlu gives up the goods or just hints...;o) These are GREAT tests, btw... AS
Freestuff | IMDB
Credits | Personal
Site
Set Speculat halo to true white, set difusion to white and turn it to 100, turn reflection to 40-60 crank on blurry reflections place it inside a dome and bam. As I thought, specular halo is the radius of the sample rays it takes to average, true white would be 180 degrees, these blur beyond looking reflective and take on the lighting of the environmental colors. Hope this helps.
Does it matter what material you start out with? (for your objects/mesh) Does it matter what sky preset you are using? I know to disable the sun, but with the way I had done it before, I had to use the White sky setting, and then disable the sun. (for some reason) It's kinda working, looks really washed out though. And, unless I crank the ambience on my dome, it renders like its a negative. Strange and interesting. AS
Freestuff | IMDB
Credits | Personal
Site
Freestuff | IMDB
Credits | Personal
Site
Freestuff | IMDB
Credits | Personal
Site
The shadow is actually fairly natural, it would make sense if you could see the light probe. I guess just a plain white dome could be used. Right on about the sky color!, I had to make sure I used a white sky setting and turn all the clouds and everything off or to zero and especially make sure the "Background Hue was set to white, instaed of the brilliant blue it seems to default to. Otherwise, you do blue tones and not the color of the light probe. This is a cool technique overall, but I still would use my old technique and not use blurry reflections, only because I myself would want realistic relections. (see link in post #8) But, I think this cool radiosity technique might work great for a layer in a muti-pass technique. AgentSmith
Freestuff | IMDB
Credits | Personal
Site
Well, I have to take one point back. I tried this with a plain white dome, same shadow appears, probably not a shadow but the reflection of the model on the ground plane.(?) AS
Freestuff | IMDB
Credits | Personal
Site
Glad you did post, this technique of yours looks a lot like radiosity renders by higher end programs. (IMHO)
Freestuff | IMDB
Credits | Personal
Site
very nice, subtle pic
Freestuff | IMDB
Credits | Personal
Site
But then I don't get any specular hits, but I understand what you're saying, I (obviously) haven't messed around with the blurry reflection aspect much. I'll have to try this with the vase pic or similar, see how I can get it to come out.
Freestuff | IMDB
Credits | Personal
Site
Well if you use an environmen with visble light points (like the windows you have) then those fake the specular highlights. So as long as there is some visible source of light, it will look like a highlight on the surface. The glass ball in the above cornell box pic also have almost no specularity....it's just reflecting and refracting the bright visible light surce at the top.
WHoa guys.. Agent said: "This is a cool technique overall, but I still would use my old technique and not use blurry reflections, only because I myself would want realistic relections. (see link in post #8)" You CAN control reflections and transparency EVEN when using blurry transmissions (transparency, like glass) and blurry reflections. All you have to do is set the SPECULAR HUE from either pure black (Renders that materials reflection without any blur) or to pure white (renders that materials reflections or transparency blurry) Any hue in between is a mix. The more black you go the clearer the reflection or transparency will be and the whiter you go the blurrier it will be! The really cool thing about that is for each object you can set the apparent blurr or clearness without worrying about blurred transmissions or reflections screwing up say a car window :)
