Wed, Nov 13, 7:36 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Texturing Vertex objects for bone animation
Nicholas86 ( ) posted Sun, 16 February 2003 at 3:59 PM ยท edited Wed, 13 November 2024 at 7:35 AM
Any tips on HOW to do this? I modeled a butterfly in the VM modeler all one piece, now I wish to texture it! I named the body, and wings seperate and mapped how I assumed would be the best, cylindrical for body and flat for wings. Yet I can't seem to get the texture room to agree with me. Any tips would be appreciated!? Brian
Kixum ( ) posted Sun, 16 February 2003 at 4:25 PM
It sounds like you're on the right track. Could you post your shader tree? -Kix
-Kix
Nicholas86 ( ) posted Sun, 16 February 2003 at 4:26 PM
haha..thats the problem I don't know how to go about the shader tree and getting it to work. I haven't messed with layers, and the like that much.
litst ( ) posted Sun, 16 February 2003 at 6:39 PM
The best way to texture a model for bones animation is UVmapping by far . Avoid procedural functions or mappings other than parametric, they don't work well with bones :(
Nicholas86 ( ) posted Sun, 16 February 2003 at 6:53 PM
I neeeed help!!! I don't want to exit Carrara.
litst ( ) posted Sun, 16 February 2003 at 7:28 PM
Well, i'd do the UVmapping in UVmapper first ...
ewinemiller ( ) posted Mon, 17 February 2003 at 3:05 PM
Brian,
It's probably something that could use a good tutorial, but here is what I did for the glider in the Anything Grows and bones tutorial. You can see the AGro and bones tutorial at
http://www.digitalcarversguild.com/tutorials/agrobone/index.htm
  1. Modeled the creature using the VM, with lots of help from Project Gemini.
  2. Sliced it up in the VM to seperate named meshes using disconnect and then cut and paste. There may be an easier way. I also named polygons the exact same as the seperate meshes. Some things like the named meshes, some like the named polygons so it's useful for them to match.
  3. I set all of them to a reasonable mapping mode depending on the shape.
  4. I exported it as an OBJ and use Mapping Magician (just do a search on google) to normalize and layout the UV space. I liked the way it allowed me to resize the various mesh parts better than UVMapper does.
  5. Saved and reimported into Carrara. Also saved a template file.
  6. I then built a few mixer textures for transitions (like skin to lips, lips to mouth) and used those to texture the object in Carrara using some of litst's shaders as a starting point.
  7. At this point the bones made it look terrible because the procedural textures would change as it animates so for one last step, I exported it back out to OBJ and had it create textures from procedural shaders. It took a long time, but when it was done, I replaced the procedural shaders with a single texture.
Good luck,
Eric Winemiller
Digital Carvers Guild
3D extensions for Carrara
http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave plug-ins
whkguamusa ( ) posted Mon, 17 February 2003 at 6:48 PM
Some times you have to bite the bullet and use Carrara with other applications. mdc
Nicholas86 ( ) posted Mon, 17 February 2003 at 9:21 PM
Well share how!!! lol...Steve
