Forum Moderators: Staff
I should have mentioned I am using Poser 4.0.3.126., on a PC. I can't see anything strange in the pp2, there is no "castsShadow" line in the pp2, but then neither is there one in the box.pp2, and that does cast shadows. I tried putting a "castsShadow 1" line in the pp2, but that did not help. Cast Shadows is on for the Render Options, and for all three lights. "castShadows 1" is set in the "renderDefaults" section of the "preferedState.pz3". I can't think of anything else to try.
I have never had good luck using the poser ground in any version of poser. I have always needed to create ground or floor. I have used the squares, but more often, a very thin cube. The squares (mostly the one sided one) sometimes aren't visible while posing... so, the thin cube seemed to work better for me. (I agree with anyone who says we shouldn't need to resort to these silly tricks and techniques. Hehe). Good luck, Ericroy
![file_51217.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_51217.jpg)
I had just finished making a simple door figure out of one Poser square and some Poser boxes and things. I did a render and noticed that the sections of the door made out of the square do not cast shadows. I loaded a new square and a box into the doc window, and sure enough the box cast a shadow, but the square (double sided) did not. Two questions: "Casts Shadows" is enabled in Properties box, so Why does the square not cast a shadow??? All the Poser props seem to cast shadows except for the suqare and the one sided square (or is it just on my system?). The other question is; is there any way I can make my door figure cast shadows for all its parts, or do I have to rip it apart and replace the square with a box?
