Sun, Jan 19, 11:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 7:23 pm)
Subject: wire frame renders.......
Speedbump ( ) posted Mon, 19 May 2003 at 6:42 PM ยท edited Sun, 19 January 2025 at 11:16 PM
Okay folks here it is....Stupid question of the day. I have beat myself up for quite awhile trying to figure out how to render a wireframe figure in poser. I thought it was possible but now I don't know...PLEASE HELP ME, I BEG OF YOU KIND PEOPLE. (Yes that was a scream).
SamTherapy ( ) posted Mon, 19 May 2003 at 7:03 PM
Several schoools of thought on this one, and naturally, I think my way is the best... Texture your model with the UV template, and render as normal. If you want to have the bits in between as see through, make a transparency map from the template. You could also make a composite texture by blending a regular skin tex with the UV template in Photoshop, then applying that to your model.
denden ( ) posted Mon, 19 May 2003 at 7:09 PM
It's also easy to do it in trueSpace and probably other 3D proggies.
maclean ( ) posted Mon, 19 May 2003 at 7:25 PM
Set the document style to wireframe, then go to Menu/File/Export/Image and choose jpeg, psd, whatever. That will give you exactly what's on your screen, lights, magnets, and uncle tom cobbley and all and all... mac
wyrwulf ( ) posted Mon, 19 May 2003 at 10:08 PM
Render a one frame animation as an image file using display settings.
Nance ( ) posted Mon, 19 May 2003 at 11:00 PM
or, yadda yadda blah blah, etc. (translation: Use huge UV template as trans-map)
