Wed, Jan 22, 11:09 PM CST
Subject: QUESTION ON WATER
alvinylaya ( ) posted Wed, 21 May 2003 at 9:10 PM · edited Wed, 22 January 2025 at 11:08 PM
Here's a question Iv'e been wanting to ask. WHAT I WANT: A tropical beach water as shown in the first 2 pics. The water starts out transparent in the shallow areas, as it gets deeper it turns greenish/emerald, then it gets more blue as as the depth increases. WHAT I'M GETTING: So far regular Bryce water doesn't seem to behave this way, the bottom left pic is a sandy terrain with "Carribean Resort" water. The one on the right has a little bit of that depth but it's not because of the water! it's the terrain. hehehe. I just used altitude color. It still looks kinda funny. Does anyone have any other way to attack this problem?
shadowdragonlord ( ) posted Wed, 21 May 2003 at 9:21 PM
Hmmm.... do you think you could post a screenshot of the water material? Might help... Also, is this a water plane, a slab, or a terrain water? If a terrain, is it set to solid? Just some questions... (bows)
Aldaron ( ) posted Wed, 21 May 2003 at 9:50 PM
You mean something like this? This was a bit of a challenge to figure out which is what I like. :) Create your beach terrain then use a cube and make it the same size as your terrain and apply the carribean resort water material. Now select the terrain and go to the editor/pictures and copy to get the G2H, will will use this for several things in the alpha channel. Exit terrain editor. Now select the cube and set the material as pictured above. Paste the g2h in the B channel of the material editor using picture (like you would if you were using a .jpg for a texture). Make sure you paste it in both the color and alpha sections (1st and 2nd boxes). Presto, now where it nears the beach it's clear and where it's deeper it's a darker blue. :)
Aldaron ( ) posted Wed, 21 May 2003 at 11:12 PM
One important note, if you don't make this so one cube and terrain cover the entire field of view and instead decide to go with tiling terrains (you'll have to copy each g2h of the terrain to the corresponding cube of water) make sure that when you have everything in place select all the cubes of water, make them positive then group them. Otherwise you'll get these nasty grids making it look like the water is actually cubes instead of all one body of water.
Zhann ( ) posted Thu, 22 May 2003 at 12:48 AM
Thanks for the info
Bryce Forum Coordinator....
alvinylaya ( ) posted Thu, 22 May 2003 at 1:32 AM
Wow, that's an awesome technique. Thanks much, now lemme try it. hehehe.
TheWanderer ( ) posted Thu, 22 May 2003 at 4:22 AM
G2H?
Rayraz ( ) posted Thu, 22 May 2003 at 5:45 AM
greyscale to height. The displacement method used by the Terrain Editor
(_/)
TheBryster ( ) posted Thu, 22 May 2003 at 6:34 AM
When you create an infinite water plain, you can select 'Volume' via a little v beneath the create pallette. This creates a water plain that you can control the depth of the water with......
Aldaron ( ) posted Thu, 22 May 2003 at 7:44 AM
Bryster that's true but the water is a uniform transparency and color. It doesn't work the way it's supposed to. As the water gets shallower it should get clearer which the way I posted above helps acheive.
Incarnadine ( ) posted Thu, 22 May 2003 at 11:57 AM
I have an idea I want to try tonight when i get home, will post then whether success or not.
TheBryster ( ) posted Thu, 22 May 2003 at 2:34 PM
Aldaron: I think some of the Bryce Water presets allow for this...........
scotttucker3d ( ) posted Thu, 22 May 2003 at 3:07 PM
I was up late last night cracking this nut and I have a solution using volume color, altitude, and a volumetric slab. A cube could also be used if the camera is in tight and you don't see the edges of the cube but I chose a slab because it is an infinite volume - kinda like the ocean ; ) First of all you were on the right track using the altitude color, but you need to use it in the water - here's how. I'm going to upload a series of jpegs to explain it so hang on. -Scott
scotttucker3d ( ) posted Thu, 22 May 2003 at 3:09 PM
1st step - you need to add a volumetric slab to your scene.
scotttucker3d ( ) posted Thu, 22 May 2003 at 3:13 PM
2nd step - start with a preset and make a new material - click on volume blend -altitude.
scotttucker3d ( ) posted Thu, 22 May 2003 at 3:16 PM
step 3 - add the basic altitude texture and modify in the DTE
scotttucker3d ( ) posted Thu, 22 May 2003 at 3:24 PM
step 4 - make the channels and colors look like this in the shallow texture editor. The altitiude is driving where the color goes from transparent color to volume color - mostly clear to deep blue. Notice we only use the transparency channel globally. This gives full control to allow murkiness if needed ; )
scotttucker3d ( ) posted Thu, 22 May 2003 at 3:30 PM
Here's a test image showing a beach terrain - and the deep pools get colored by the volume color. Notice the deep distant water is full blue and the shallows are mostly clear. I hope this mini-tut helps you with your current and future tropical scenes. -Scott : )
Aldaron ( ) posted Thu, 22 May 2003 at 3:39 PM
That works much better than my solution, I'm going to try it now.
scotttucker3d ( ) posted Thu, 22 May 2003 at 4:32 PM
Go for it. Your solution was very creative Aldaron - mine's just easier to apply generically. I'd love to see a test image. Scott
Doublecrash ( ) posted Thu, 22 May 2003 at 4:55 PM
Scott, that's great! I saved this page for future reference. Thanx!
Aldaron ( ) posted Thu, 22 May 2003 at 5:20 PM
Definitely go with Scott's solution. It may take some tweaking of materials and the altitude filter in the DTE to get what you want but it's well worth it. I added some abience to the water material and TIR since light bounces all around in water. And to get the sand darker at the water's edge I just copied the G2h and brought it into photopaint then smeared the darker areas further into the light area until I got it where I wanted then used it in the diffusion value channel.
shadowdragonlord ( ) posted Thu, 22 May 2003 at 8:22 PM
Wondeful work, Scott! I've always wondered how to mate the Altitude Blend with the DTE filters, and there it is! Thanks for the tips, everyone...
Incarnadine ( ) posted Thu, 22 May 2003 at 9:37 PM
LOL, I was just going to do exactly this (finally got home - it's 22:33 here). Thanks for confirming my hunch! (and saving me a bunch of work even if you didn't know about it!)
Aldaron ( ) posted Thu, 22 May 2003 at 9:44 PM
A closer look
scotttucker3d ( ) posted Fri, 23 May 2003 at 1:19 AM
Awesome! Glad everyone is having fun with it. Yeah it does take tweaking the altitude in the DTE but the results are sure worth it. Also you can paint in some terrain details in the pools and they will look like reefs below. Have fun! Scott
alvinylaya ( ) posted Fri, 23 May 2003 at 2:37 AM
Gee thanks guys!!! These are brilliant ideas!!!
