Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
I had a couple of requests for the info I sent to Mechanismo, so I will put it here for your convenience. Firstly, you should get the recent update to Apophysis. Here is something I wrote some time ago, and most of it still applies: Here is how to get an Apop flame from Apop to UF3. Before you do anything in Apophysis, open it and choose Options on the Tool Menu, then choose the Flame UPR tab and change the right column "File:" to enr.ucl. Generate the flame and edit it until you are happy with it. On the main window for Apophysis, you will see on the 3rd line icons for a variety of things. The first is an open folder, the second a floppy disk ( open file, save file) and so on. The third item is 2 sheets of paper, one on top of the other (copy) To pick up the file you just created, simply click on that button. Open UF3. You should have a fractal window open. (usually this will be the default fractal, but any one will be fine.) Right click in the fractal window and choose paste from the popup menu. Thats all...your flame will appear! It may take a moment or two, (or way longer, lol) so be patient. Have fun, try to eat and sleep occasionally! :)
Fractals will always amaze me!
Attached Link: http://www.apophysis.org/
Vampi, Apophysis is FREE !!!!!!!!!!! And it's great fun, too. TresFractals will always amaze me!
hey, i had that problem when i first tried apophysis, too! (seems awfully strange that it was only, like, 2 weeks ago... and now it has me in it's grasp and i can't shut the darned little program off) anyways, the problem was that it was looking for the enr.ucl file, and i had it as enr3.ucl... that might be backwards.. i just copied whatever one it was that i had, and renamed the copy whatever it was that i DIDN'T have, and worked fine after that... now, if i could just figure out how to make the REST of it work... laughing ...russalynn
Getting the flame from Apophysis to UF is about the only part I really know how to do. Russalynn, have you gotten the new update? The original Apophysis had the default pointed to enr3.ucl, but the new update has it pointed properly to enr.ucl. There have also been a few bugs fixed, so it's worth getting. I must say, I am really enjoying your Apophyis work! Please remember to eat and sleep occasionally!
Most of the changes in shape should be done right in Apophysis by using the edit feature. Once you get a shape you like, use the copy button and bring it to UF. In UF, you can correct the colors, thicken it (increase the iter.density), layer it with other fractals or flames, put in backgrounds, make frames, turn it upside down, zoom into it, etc. You actually can change the shapes there too, but it's much more difficult. Hope that helps!
im fairy new at playing with fractal proggys but im really impressed with what they can do.... so ive got ultrafractal 3.02 and Apophysis... but what i dont understand is how do you make somthing in apophysis and get it to work in UF??!! every time ive tried i just get ''contains errors'' this is reallllllllly starting to get on my nerves !!! so whati need is what do i export/save to work in Uf? ...any help would be very appriciated!! :) cheers!!
