I've not found any way to copy just one component. When I get one I like, I've just written down all the settings (only about a gillion of them), then started a new texture and used those settings. Long way around it, but it works. Hopefully someone will come along and say "sure, it's just..." ~click, click, click~ :o)
Just click on the texture and drag it where you want it. Hope I'm understanding that is what you want to do. Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
I can drag from component 1 to component 2. what I want to do is drag from component 2 in texture A and drop it into component 2 of texture B but I can't open two component windows simultaneously. Is there a way I can copy all the settings from texture A into the texture B channel. If not I'll have to open wavey in channel B and duplicate all the noise filter phase and color changes I did to create channel A.
Yea...do what i ALREADY POSTED.... save the texture in channel a with the TOP BUTTON ON THE COMBINATIONS WINDOW IN THE DTE. Then, marble channel B with whatever you want, SHIFT CLICK ON THE UPPER RIGHT ARROW OF CHANNEL B. Then, simply choose your texture for channel B. It's not that hard, if you would just READ.
Thanks Slakker, Sorry I'm so dense. I can't keep the texture window open to look at what you are talking about. In order to use the browser I have to be out of the editor and minimize Bryce. I'm sitting here while the room I was in clears of THF and acetone. I Saved the texture as rusty in sand and reloaded it into B Thanks again,
I guess I should clarify that, the Materials Lab (were the preview window is and all the diffuse, ambient, etc,) there are 4 channels, each one of those four channels can be changed independently in the Deep Texture Editor (which has 4 components), the image in the channel is a texture, after you're finish with however many channels you've tweaked in the DTE, that final texture is the 'material'...does that make sense?
Bryce Forum Coordinator....
Arleen
