As a render, most especially for a beginner, it's not bad. Nice lighting. But, there are a blue-million naked cross-eyed Vickie pics in the galleries. Do something with her. For a headshot, show me an interesting face. You seem to have the basics down pretty well and I hope to see more from you. 1000x1000 is a bit (ok, not a bit... VERY) large for a headshot. Some people don't have a display that wide. Unless you have a pic with some very very interesting detailing going on (beyong Daz's lovely V3 texture), I'd suggest maybe no more than 800x800... The size you have it at now (465x419) allows me to see what needs to be seen and not get crazy with image size and bandwith.
Looks better than my first. Do need to fix the eyes,uncross them a bit, say move them outside between 3 to 7, and close the eyelids a bit. If you have a paint program for post, try to round the shoulders, push, smudge, clone, what ever it takes. Something I notice first off and find it distracting. You can render as big as you want, the bigger the better, for doing post work, then size down when your finished. Also save your render as a Tiff or PSD file. It saves as an Alfa channel, so you can use layers without toasting the original. You do have the basics down. Nice work.
That's a handsome render for someone just starting out :) I'd probably put some clothes on her to disguise the difference between the color tones of her face and neck and her shoulders...or maybe warm up the facial tones in a paint program. It helps to give her something to look at that would explain the slight frown in her expression, too...but that's just a suggestion. I tend to like images that tell a story. geoegress is right on the mark--render as large as your computer will let you--I usually render at about 2000 x whatever (though my Mary Magdalen portrait was rendered at 2995 X 4000 (I think...not good at recalling #'s) so that I could do the postwork more easily. I've learned to keep a backup file of things I render that large, since even my iMac occassionally balks and barfs on an image that large! Even if you're not into a whole lot of postwork yet, the larger you render, the clearer the details will look after you shrink it down to around 900 X 700 or so to post it. Good luck with your Poser experience and never hesitate to ask questions when you're stumped :)
Great start! My first Poser render was not even worth laughing at, but then I started with Poser 2 and the figures didn't even have real facial features. I would set the eyes at around 5 outwards and about 5 upwards. The way her irises are pointing downward gives her a somewhat manic expression. Your lighting is perfect! After all these years, I still have problems with lighting. I think you can do more with her than just a face pointing toward the camera. It's a nice portrait, but she has a slightly severe expression. Maybe give her a little character like a hint of a smile or a slightly arched eyebrow. Keep up the good work. If this is your first render, you're going to be doing some fantastic stuff once you get the feel of it. Melanie
