Excellent observation!
spurlock5 is absolutely right!
The "hither" parameter can be animated just like the other camera parameters - provided that the "Animation Lock" is OFF.
Let your imagination run wild.
What can YOU think of? Huh?
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://www.renderosity.com/messages.ez?&Form.ShowMessage=1180006
Just click the "link" to get back to Dr Geep's "Camera" tutorial. cheers, dr geep ;=] P.S. Oh, and BTW ... As usual ... All ... questions, comments, observations, flames, etc., etc. are welcome.Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
Thanks an zillion times Dr Geep. I will have another dial to play with ! And a mini tut for me : I'm honoured ! (yes, I know : being honoured for my ignorance... But hey, this is a DR GEEP mini tut !). (PS : your tube looks more like a scanner : MRI machinery leaves much less room for the patient : Dr Geep couldn't go inside together with Miss Posey ! Back in my hospital days, we used to call it "the pizza oven" ! )
You're welcome a zillion times compiler.
Yup, I know the MRI leaves less room (been there, done that), but then you wouldn't have been able to see Dr Geep's beautiful face, no? ;=]
Ignorance?
Maybe this bears repeating, again.
(is that repetatively redundant?)
"We're all ignorant, 'cept on different subjects."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Cyhiraeth, You can use it to get inside walls of rooms if there isn't enought space to manipulate the camera. It is also handy for getting in close to pose without stuff getting in the way. Sometimes you want to make things invisible, but often you don't. Say that you were positioning fingers on a violin... if you make the violin invisible, you can't place the fingers. Using hither, you can press the proper strings for an A. Hmm... a violin isn't bulky enough, make that a nice curving pipe organ! Carolly
You know, ....... open mouth, insert foot.
Well, gang, Doc's old "friend(?)," Poser's Scale, has once again reared it's ugly head and I'm afraid that Doc Geep "went for the bait."
One of the other threads in this forum made an inquiry about Poser's scale and Doc tried to contribute some of the information that he has accumulated on the subject.
But ...
The following excerpt is from part of a post in another thread in this forum.
"However, in the matter of Poser Scale Units for Poser 4 AND for Poser 5, Dr. Geep is just wrong, Wrong, WRONG. He uses circular logic and mathematical mumbo-jumbo to obfuscate the issue, and he seems unwilling to consider even VALID proof which contradicts his pet theory. Furthermore, he claims that CL has somehow verified his theory, but my sources at both Cl and Egisys have verified that the scale in Poser has NOT changed since the introduction of Poser3 and has remained consistent in Poser4 and Poser5!. (although there is a bug in the P5 scale-translation process which I will describe below). The FACT is that the definition of one Poser Unit is no different in P5 than in P4."
This type of statement is what causes Doc to "lose his spark."
(and ... he ran out of mud)
Sorry, I felt the need to vent.
(end of rant)
cheers,
dr geep ... :o]
edited 10/5/2019
"Her ghost cried, 'Cockles and Mussels, hi-lay-ha-lie-low!'" but the song doesn't mention if she served them steamed. BTW, that same person posted over in PoserPros that I was brilliant, but totally tactless and antisocial... which made him wrong on all three counts. November will be three constant years of this migraine (I'm operating on half a brain, which is why I had the MRI... which shows the beginnings of dementia... I've lost a chunk of my vocabulary). The brain still spins, but it doesn't sparkle. As for being tactless, I can use words as weapons, but I don't do it accidentally. Antisocial? Well who had the Poser party, opening her house to total strangers? So, as far as I'm concerned, he "is just wrong, Wrong, WRONG!" So I can ignore him. In the grand scheme of things does it matter if the Poser scale relates to Max's scale, etc? Or is it more important to have internal consistency in your choice of program? Unless one is creating a character from real life, where the absolute size is well known and could matter, who really cares if Vicky is 5'7" or a smidgen more? She doesn't have real woman proportions anyway! If you are building props, you need them to be close, but real world chair sizes vary, so why get freaked out over half an inch in the virtual world? Not: I have made die drawings for custom aluminum extrusions (sloped glazing) and for vending machine parts (6 years combined experience as a design drafter). Those tolerances are precise, and need to be. If Vicky is 8 heads high, a ten-thousands of an inch tolerance in measuring her height is missing the target. Carolly
Thank you di.
Thank you Carolly - I needed that.
cheers,
dr geep
P.S. Poser party????????????
Where?
When?
Why? (wasn't I invited?) ;=[
Nevermind, I think I already know the answer to that last one. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1352228
Anybody interested in what the FULL CONTEXT of my statement was can go here and read it for themselves. I won't be deleting it, but will stand by everything said. I'm genuinely sorry that some people insist on taking such matters personally when they are not meant (or expressed)that way.ronstuff said:
"I'm genuinely sorry that some people insist on taking such matters personally when they are not meant (or expressed)that way."
The following statement appears to be expressed to a "person", i.e., Dr Geep.
"... Dr. Geep is just wrong, Wrong, WRONG."
AND ...
I DO take that statement personally.
Can it be viewed any other way?
no cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=936284
ronstuff,May I respectfully suggest that you read the text in the very first post in the thread at the attached link.
Here is the specific lines of text to which I refer.
(It is taken out of context, I might note.) ;=]
********** excerpt ***********
First, let me say that I know that this (i.e., scale) can be a ...**
controversial subject**
... but I'm going to try and tackle it anyway. ;=]
There are many opinions (standards?) out there in "Poserland" about the "Real World Scale" in Poser.
But, please keep this in mind ... My opinion (i.e., standard) is just one of them.
I would like to share this standard with you because I have found a system that appears to work very well inside Poser.
******** end of excerpt ********
you said:
"But THAT is NOT the case because you have presented an issue in the form of a TUTORIAL which purports to be factual, and THAT is where I must take exception and hold you accountable - NOT to your personal views, but for your presentation of FACTS."
Repeating, again ...
"But, please keep this in mind ... My opinion (i.e., standard) is just one of them."
Can you read this? .... "My opinion ..."
"My OPINION ..."
My opinion is NOT fact.
It is MY opinion, and that is all it is.
But then I don't expect that you will see the point here either. no sigh
(ain't cut 'n paste great ;=] )
cheers,
dr geep ... :o]
edited 10/5/2019
runstuff, I was quoting from memory. You weren't teasing; you were attacking, in an arena where you could get away with it. Maybe you think that if you drive off all other sources of knowledge or experience, people will sit at your feet to lap up your precise and absolutely clear prose? Why should they pry off your bitter belittlements of others to find what may or may not be a nugget of truth? There are wells in San Jose where the water tastes of sulphur. It is nutricious and perfectly safe and necessary for life... but it stinks. The same thing can be said of your attitude. You may present facts necessary for the advancement of knowledge, but the presentation suffers from malodorousness and contentiousness. There are many wells here; we don't need to contend with your stench. Carolly
Great work on hither, agreed and thanks! I didn't quit, I got CENSORED by someone who apparently has no regard for truth and THAT is a FACT. Sorry to burst your bubble. I think most of your work is fantastic, Geep, and have said so on several occasions. And I agree that we should not let one littel point stand in the way of progress.
cheers,
dr geep ... :o]
edited 10/5/2019
